Complete! Explanation of sport functionality, please
Old Aug 2, 2017 | 04:10 PM
FullChat's Avatar
Default Complete! Explanation of sport functionality, please
I have the basic idea, but I'd appreciate a source that give ALL of the changes associated with the various sport adjustments: Dynamic vs. Normal, Sport vs. Drive, and DSC Off vs. TracDSC vs Full Nanny Mode. Any good factory reference material online?
One of the things that I'm quite curious about is, in full DSC mode, will the nannys will cut power drastically due to wheelspin, or simply limit power to what the tires can handle (dial it back just a little to regain grip). I was under the impression that the car cut power drastically only when a yaw problem was detected, and I'm getting drastic power cuts when there shouldn't be much of a yaw problem... and I often see the Traction Control working furiously when I accelerate without drastic power cuts. Maybe its saving my ***, cause from what I feel, I'd just keep it floored and trust my hands... and No, I am not yet comfortable enough with the limited rear grip to turn all of the nannies off, and I haven't worn out the Conti's yet, so no Michelin's for me yet.
I'd just like to know what the car is doing so I can learn how to drive around it...
Old Aug 2, 2017 | 04:21 PM
DJS's Avatar
DJS
Sadly, I've seen no such reference. This is closest I've seen...
https://www.dropbox.com/s/wskjex70o2...ntrol.pdf?dl=0
Note that the 'dynamic launch' mentioned only applies to the V6S.
Old Aug 2, 2017 | 04:40 PM
stmcknig's Avatar
You need to be One with the Force, Luke...
Old Aug 2, 2017 | 07:21 PM
FullChat's Avatar
Thanks for the link, but I'd really prefer a lot more detail than that...
Fairly soon after I leave home, I have a Stop Sign before turning onto a two lane road (one each way) with traffic going between 60 and 70 MPH in a steady stream from both directions. I've been experimenting with techniques that will allow me to merge into traffic ;-)).
When I go in 1st, I get entirely too much wheelspin. If I short shift to 2nd, I can get on the gas harder and earlier, but sometimes I get the big power lag. I could still be turning a little, but not much... I really wish that I didn't have to be completely straight before hammering it.
I really respect the guys that can really hammer the big V-8s - if I have problems putting down 340 hp, the big cats must really have problems!
Old Aug 2, 2017 | 07:29 PM
FullChat's Avatar
Luke and Hans have it easy - Yoda told me that the Millennium Falcon really puts the power down - hell, it made the Kassel Run in 12 Parsecs (I think they had to replace the P Zero's after the run)...
Old Aug 2, 2017 | 08:23 PM
Unhingd's Avatar
Full DSC over-modulates when reaching the limits of traction. Mine will cut power for a noticeable period of time before full power is regained. I have found that TracDSC is the best compromise between abstinence and totally unprotected sex.
Old Aug 3, 2017 | 02:19 PM
Itismejoshy's Avatar
i agree! full "nanny" is very moderated and will **** it down quick if wheels are not perfectly strait. TracDSC is much better and will let you get fairly "tail sideways" before it also shuts it down...
Wish i had the ***** to shut if off completely...
Old Aug 4, 2017 | 07:39 AM
Originally Posted by Itismejoshy
i agree! full "nanny" is very moderated and will shut it down quick if wheels are not perfectly strait. TracDSC is much better and will let you get fairly "tail sideways" before it also shuts it down...
Wish i had the ball s to shut if off completely...
autocorrect really got me on that...^^^
Old Aug 4, 2017 | 10:18 AM
lizzardo's Avatar
The only time I don't drive in TracDSC is inclement weather. I find the power cut too abrupt and more upsetting than slip or spin.
Old Aug 4, 2017 | 10:51 AM
jfranks's Avatar
To really improve traction, you may want to consider better tires if you haven't replaced the OEM Pirelli's.
In dry weather, I always drive with Dynamic mode and TracDSC. I'm in a V6S manual.
Old Aug 4, 2017 | 01:30 PM
bigdaddy's Avatar
How much "tail sideways" would you say it gives you? Would you still consider it fairly safe with TracDSC? Or do you really have to be an experienced driver to handle it?
Old Aug 4, 2017 | 01:35 PM
DJS's Avatar
DJS
Likely depends on whether you're talking V6 or V8. I believe my LSD catches me before the traction control does. I'm a cautious driver, but occasionally I feel just a bit of spin/slide before it grabs.
Would like a big parking lot to play in, to get a feel for the limits of traction. I've tracked it a couple of times (in TrakDSC), but I wasn't willing to explore the limits there, as there may have been consequences.
Old Aug 4, 2017 | 01:48 PM
bigdaddy's Avatar
I was mostly wondering about the V6.
Old Aug 4, 2017 | 02:57 PM
jfranks's Avatar
Even on the V6, if you turn traction control all the way off, it becomes entirely possible to lose control entirely.
TracDSC is great in the dry. It'll let the car get sideways in a turn, let it slip a bit on launch, but it'll catch you before you go sideways.
However, TracDSC is not magic. In wet weather (or with some effort,) you can still definitely get yourself in trouble.
For anything other than donuts, I won't turn traction control all the way off.
Old Aug 5, 2017 | 12:13 AM
bigdaddy's Avatar
Sounds good. I'll give TracDSC a try. (Famous last words)
