Correct offset for rims
Old Nov 18, 2019 | 03:05 PM
Ltrain925's Avatar
Default Correct offset for rims
I’m having a pair of custom wheels made, I’m sticking with 20s 20x10.5 and 20x9 with stock 295/255 tire size. I’ll be lowered on the VAP springs also. What is the correct size off set to sit flush without any rubbing? From what I’ve gathered the stock f type R rims +15MM spacers are the limit on stock size rims and tires, so would that be the correct offset? I know 17MM spacers iv heard it rubs with stock size so I don’t want it that aggressive. Just want to clarify before I have them made, thanks!
Old Nov 19, 2019 | 08:20 AM
Unhingd's Avatar
You can go safely with 40mm offset in front and 23mm in the rear. That’s the same as using 15mm spacers with OEM offset wheels.
Old Nov 19, 2019 | 08:48 AM
watson6505's Avatar
since we are talking offsets, I took this from a prior post and just want to confirm these are still good based upon the following sizes:
20x11-32mm offset: will accommodate 295/30-20, 305/30-20 & 315/30-20 (though, I've not yet seen a 315/30-20)
20x9.5-45mm offset: will accommodate 255/35-20, 265/35-20 & 275/35-20
Assuming 20x9.5 and 20x11 (1/2" bigger than stock) with no spacers, option to go up to 305, no rubbing, and a nice flush look without kicking too much/excess debris to the the bottom of the vehicle.
Is 32 rear and 45 front the recommended?
Old Nov 19, 2019 | 08:56 AM
Unhingd's Avatar
I need a cuppa coffee for this exercise. I’ll get back to you.
Old Nov 19, 2019 | 02:36 PM
RGPV6S's Avatar
What are the stock wheel/tire sizes and offsets on the F-Type R? Checking because I'm tempted by the BC forged group buy.
Old Nov 19, 2019 | 08:39 PM
Unhingd's Avatar
Front: 20x9 55mm, 255/35-20
rear: 20x10.5 38mm, 295/30-20
garysaunders85
Mar 26, 2019 09:27 AM
mrathell
Jun 5, 2017 01:56 PM
Freddy Stroman
Aug 1, 2016 11:44 AM
gr8dane
Mar 18, 2015 01:45 AM
Jandreu
Mar 8, 2015 09:21 PM
