Could someone do the OS math
Old Aug 6, 2016 | 10:27 PM
polarisnavyxj's Avatar
Originally Posted by Unhingd
1. Given available tire sizes, you wont do better than 305/30-20. The next size up to retain a similar diameter is the 345/25-20. However, it requires a 12"-13" rim.
2. You can't use the 10.5" on the front at all since it pushes the face more than 33mm outward. Close to an inch of tire would not be covered by the fender.
Is a 59 offset right for an 10.5" front then?
Old Aug 6, 2016 | 10:52 PM
ShaunPA's Avatar
There is no need to run a 10.5 in wheel in the front.
Old Aug 7, 2016 | 06:37 AM
Unhingd's Avatar
A 56mm offset would give you the 15mm extension you are looking for.
Agreed: a 4-square tire/wheel application ( same size all around) is not necessary and only looks good on cars that have no accentuated rear flares like the F-Type has. (My C4 Vette looked good with 315s front and rear). If you want to increase the front wheel/tire dimensions proportionately to the 11.5" rear with 305s, I would suggest using 265/35-20 tires in front. That will closely match the diameter of the 305/30-20 rear tire and can still be mounted on your proposed 9.0" rim.
Old Aug 7, 2016 | 09:06 AM
ShaunPA's Avatar
Couldn't have said it better.
Old Aug 7, 2016 | 10:07 AM
Default info - crisp
Ferrada Wheels FR2 20x 9.0 5x108 et35 Matte Black w/ 265/35-20
Ferrada Wheels FR2 20x11.5 5x108 et30 Matte Black w/ 305/30-20
Pilots and the extra inch should greatly improve handling in the sloppy rear since i don't have 4wd!
You guys are the best!
Old Aug 7, 2016 | 11:11 AM
ShaunPA's Avatar
Mpss in oem sizing is enough. I don't feel the need to move up in tire size
Old Aug 7, 2016 | 02:38 PM
Unhingd's Avatar
+1. OEM sized PSSs will resolve the squiliness. I'll move to 10mm wider front and rear as the current ones wear out just for the looks.
Old Aug 11, 2016 | 04:39 AM
  #28
Default One last question on this topic
20x10 51os
20x11.5 34os
Old Aug 11, 2016 | 10:48 AM
schraderade's Avatar
20x10 51os
20x11.5 34os
How reputable is Ferrada as a vendor? The FR2's look great but I'd be concerned about what their quality reputation is.
Old Aug 11, 2016 | 11:35 AM
  #30
SinF's Avatar
I know, practice "don't go nuts with the throttle", but on anything but a perfect road I find I can't get into full throttle in the first gear until 5000 rpm or so. I don't think I could improve rear traction any further without heavy mods since I already have MPSS. Any tricks for getting faster into open throttle? Am I being overly conservative and should let the rear slide a bit?
Old Aug 12, 2016 | 05:29 AM
  #31
Unhingd's Avatar
20x10 51os
20x11.5 34os
That would work.
IMMD
Sep 26, 2017 07:27 PM
ericjansen
Aug 29, 2016 11:52 PM
DandyAndy
Jul 1, 2016 07:24 PM
supertek
Apr 19, 2016 12:59 PM
iownme
Apr 17, 2016 09:03 AM
