Damaged Bumper Paint
Old Jul 16, 2019 | 05:38 PM
Lavitz's Avatar
Default Bumper Paint potentially damaged by Glue - Need HELP! Pics included
So, the bumper on my car is damaged by some glue. The model S sticker was peeling off and my dad thought it was be good idea to use some glue to put it back on. He used a liquid glue that lead to dripping on the bumper and boooooom life is ruined etc etc.
Now that i've calmed down i'd like to to fix this. I tried the risky nail polish removing trick and it it did nothing. I tried clay bar and nothing.. Next step is cut and compound?
What are options to fix this?
Will Cut and compound fix this if so what do you recommend ?
Old Jul 16, 2019 | 06:50 PM
Jaggyx's Avatar
It's definitely fixable, but you have to be careful. Unfortunately, you're going to have to be quite aggressive the compound. Do you have a dual action polisher? Or are you looking for a professional detailer to fix this?
Old Jul 16, 2019 | 06:54 PM
Lavitz's Avatar
I am going to have to do this on my own, I have a test car i can practice with. So I just need a recommendation on what pad and and polish i need to buy.
Old Jul 16, 2019 | 07:33 PM
fuzzysquid's Avatar
Before you do that, what kind of glue, and what kind of nail polish remover?
If it's cyanoacrylate, then nail polish remover would work as a solvent... IF that nail polish remover is or has acetone in it. Not all nail polish remover contains acetone. I bought 100% acetone for this purpose, which is slightly more expensive and a different product than nail polish remover.
Old Jul 16, 2019 | 08:40 PM
Jaggyx's Avatar
Good point -- you might want to try some sort of solvent. I don't have any experience with solvents so cannot paint work, but I'm sure this is something that can be found out with a simple google search.
If the solvent route does not work, I would try going at it with Meguiars M105 and an Lake Country Yellow or Orange pad. Are you an Amazon prime member, by chance?
Old Jul 16, 2019 | 09:31 PM
OzXFR's Avatar
I have successfully used pure acetone to remove really stubborn resin deposits and especially "paint transfer from a scrape" marks on car paintwork.
It really is brilliant for this type of thing, just a little on a rag and a quick wipe and the deposit is gone.
No damage to the car's clear coat either.
But you need to be very careful using pure acetone, it is a powerful solvent and will attack plastics, do not get it anywhere near any plastic, vinyl or rubber parts of the car!
Old Jul 17, 2019 | 06:21 PM
Lavitz's Avatar
Oh wow, so the nail polisher did not have acetone. Should i give that a go first before compounding?
https://www.walmart.ca/en/ip/equate-.../6000196731130 going to buy this and give it a go
Old Jul 17, 2019 | 07:27 PM
lizzardo's Avatar
Yes, knowing the type of glue would be helpful. Knowing the type of glue would reveal the solvent used in the glue.
I've used pure acetone on modern auto paint with no ill effects. I worked quickly and gently. A detailer told me to do this instead of orange oil based products because he said they can remove clear coat, but others here have said the opposite. I think as long as exposure is limited either would work, but can only speak for the acetone. Hopefully the solvent in the glue did not damage the clear coat and is just on top. I've used WD-40 to remove sticky stuff before, so that might be worth a try as well.
Lorali
May 5, 2019 10:38 AM
XxSlowpokexX
Apr 10, 2019 11:11 AM
accounts2000
General Tech Help
Feb 12, 2014 10:27 PM
Calhale
Jan 22, 2013 06:33 PM
jagosaurus
Sep 25, 2012 06:50 AM
