Dash cam recommendations
Old Jun 17, 2018 | 01:12 PM
powerhouse's Avatar
Default Dash cam recommendations
Looking for recommendations on a dash cam for my f-type, also has anyone used the hardwire kits or do you just use the cigarette power outlet. What's the best SD card to use. Looking at these two options:
Has anyone bought either of these from Halfords,
Nextbase Dash Cam 312GW
Nextbase Dash Cam 512GW
Old Jun 19, 2018 | 03:07 PM
NoScurdyJags's Avatar
The one thing that immediately turns me off from those cameras is their size. Imagine a rearview mirror mounted below your rearview mirror! You end up losing a lot of space. Plus, in my opinion, it looks ugly and is so out of place in our cabin.
Id suggest you get a BlackVue 750s 2 chanel.
https://www.blackvue.com/dr750s-2ch/
I have the older version (650s 2ch) and its awesome! The 750s 2ch has improved upon it with both the front and rear camera recording in 1080p at 60fps and 30fps respectively.
The video quality is great both day and night, audio quality is great as well. I would definitely recommend to hard-wire it in. I hate messing with car wiring but it was really simple to do! I have pics (somewhere) of the (empty) fuse sockets that I used. I also bought the Power Magic Pro which you area able to set by voltage level or timer, to prevent draining your car battery. I've had this thing running in my car for almost a year now and its worked fantastically. My favorite thing is that I can connect to the cameras when Im at work/home/ pretty much anywhere that has a known wifi network and check on my car if I feel the need to.
Going back to the footprint of the camera, you can see in the pics that its barely visible.
Interior shot Front Camera
Front Camera
Rear Camera
I understand that the cost of this system is more than the two you posted, but, its worth every penny!
Old Jun 19, 2018 | 03:13 PM
stmcknig's Avatar
I have the 1ch Blackvue and agree I forget it's there. I have it hardwired down the A pillar into a fuse tap with their PowerMagic box so it runs in parking mode too until the battery cutoff. Debating about upgrading to the newer 4K version.
Old Jun 19, 2018 | 03:14 PM
powerhouse's Avatar
So NoScurdyJags does the 750s come as 2 camera option together front and rear just connect together
Old Jun 19, 2018 | 03:18 PM
Powerhouse,
The 750s comes in single and 2 channel. Definitely go with the 2 channel! The setup uses two cameras, one cable runs from the front camera to the rear camera.
Stmcknig, That's exactly how I've routed mine. I too am considering the 900s for the 4k upgrade, but Id like to see real world comparison of the two before I do.
Old Jun 19, 2018 | 03:23 PM
BTW, Powerhouse, they also have the 900s 2-ch which records in 4k front and 1080p rear....
https://www.blackvue.com/products/
Old Jun 19, 2018 | 05:05 PM
powerhouse's Avatar
going for the 750s, NoScurdyJags is there much to the setup and this cloud feature it says it has, i never use the cigarette 12v socket in the centre console storage box , so will plug it in there
Old Jun 19, 2018 | 05:36 PM
The setup is simple. Just download the app on your phone and/or computer and it'll walk you through it. I would strongly suggest you get the Power Magic Pro, its another $26 usd on top of the cost for the system, plus you NEED it to be able to use parking mode. It really doesnt make sense not to use it:
https://www.blackvue.com/product/bla...-parking-mode/
In case you do decide to use the power magic pro and hardwire it in:
https://www.jaguarforums.com/forum/f...otwell-186518/
^ In this thread I show the empty slots I used in the fuse panel. In the pics you'll see the ground wire mounted with a clip, that was just for the photo, I've drilled and mounted it properly.
Old Jun 20, 2018 | 11:27 AM
Jkim24's Avatar
I just installed blackvue dr900s-2ch system in my coupe. I already forgot the front camera exists bc I can’t see it at my point of view. It have both hardwired to the fuse box in the passenger foot well. I also purchased blaclvue’s external battery pack so I can run both cameras off of that battery instead of the cars battery in parking mode.
So far so good and quality is great. I hid the wire everywhere I could in the front and sides. Only piece of wire you see is in the rear as you can’t compeltely hide it unless you make custom brackets.
Old Jun 20, 2018 | 02:06 PM
powerhouse's Avatar
How is the external battery pack wired up
Old Jun 20, 2018 | 02:17 PM
Jkim24's Avatar
both cameras are connected to the external battery pack and the battery pack itself is then wired to the passenger footwell fuse #52 and ground wire is also connected near the fuse box.
Old Aug 31, 2018 | 01:40 PM
Paul champagne's Avatar
Thanks to NoScurdyJags for the pictures. But could you clarify where you routed the wire for the rear camera? The whole side of the car, all the way to the front camera is easy, but where/how did you get the wire from the camera to the side of the car?
Old Aug 31, 2018 | 02:14 PM
No problem Paul, here are some additional pics I just took, hope this helps clear things up..
Wires go up into the headliner trim there and continue towards the passenger side.
Route the wire between the two trim pieces on the passenger A pillar, route the camera wire from the door rubber trim at top towards the rear of the car.
Here you can see the wire being routed under the plastic shroud.
Finally here is the point where the wire comes out from under the trim to meet the camera. That excess wire can be tucked under the headliner trim. I was cleaning the underside of the glass and it came out, but, super easy to hide it all under that headliner.
Old Aug 31, 2018 | 02:21 PM
Much appreciated. Thanks for the new pictures. So when you hide that extra cable under the headliner, you only leave enough slack so it doesn't pull when the hatch is open?
Old Aug 31, 2018 | 05:44 PM
That is correct.
Old Aug 31, 2018 | 06:07 PM
Uncle Fishbits's Avatar
Extremely happy with the simple and easy "Waylens". The OBD port seems to trigger a battery issue where you have to disconnect the ground to reset the system, so I don't use that. That's in the 2016MY and not sure it has been fixed or not. But great and simple little device.
Old Aug 31, 2018 | 06:44 PM
Magical's Avatar
Personally, I use a GoPro. You can mount it anywhere and then take it with you. Lots of various mounts ( removable and non-removable ) and no wiring . I switch it over to my Harley frequently. You can also install the app on your phone to view the positioning of what the cam see's and get a large sim card. Good Luck !
Old Sep 26, 2018 | 06:55 AM
Kirk Morey's Avatar
Anybody got a good solution for front and rear on a Convertible??
Old Mar 26, 2020 | 03:06 PM
David Meier's Avatar
Bump
Old Aug 17, 2021 | 07:11 AM
jackrudolph's Avatar
The dashcam footage quality is great and easy to install. I did try out the new UltraDash Dash Cam mini, but it was so close in size and the LCD screen with G Sensor made it more convenient.
