Desiring more TQ from my AJ126 motor
Old Sep 17, 2025 | 11:10 PM
SuperchargedFresh's Avatar
Default Desiring more TQ from my AJ126 motor
I have a 2016 F-Type S 3.0L the current mods on it are both upper & lower pulley’s from VAP, Mina gallery thermo intakes, TCU tune (JagMadness), e85 tune (Viezu) and non hp performance mods like go pedal, NGK plugs with heat range of 9, new OEM injectors from Bosch… I plan to upgrade to the v8 MAF housing/sensor and switch to the ps4s I’m currently running DWS06 plus 305’s in the rear BUT what else can I do besides adding a WMI & paramount intercooler to gain better TQ out of my car?
Old Sep 18, 2025 | 04:56 AM
bfrank1972's Avatar
Easiest way is when you upgrade to the V8 MAF, bring the rest of the V8 with it.
Old Sep 18, 2025 | 07:50 AM
Haalex's Avatar
Yep. With all you've already done to it, the best and cheapest solution is probably to get a V8-powered car.
Also, with all you've done you should be pushing close to stock V8 torque (500lb.ft IIRC)
Old Sep 18, 2025 | 06:16 PM
Borbor's Avatar
Have you done anything to reduce your unsprung weight?
Old Sep 18, 2025 | 06:27 PM
that’s the next move I’m making is weight reduction & lowering springs from VAP
Old Sep 18, 2025 | 07:47 PM
eeeeek's Avatar
This. You will get huge gains by going with lighter wheels and rotors. The rotors alone can save 10+pounds per corner. This will be a noticeable difference.
Old Sep 18, 2025 | 08:05 PM
waldo's Avatar
Earlier this year, I installed Velocity AP progressive rate springs, Velocity AP/Girodisk lightweight 2-piece front brake rotors, 20" VS Forged wheels, and Michelin Pilot Sport 4S tires on my 2016 F-Type (base-trim, 6-speed manual). Last year I installed a Quaife ATB differential. A previous owner installed a Velocity AP lower crank pulley and tune. I don't know that I could quantify the improvements from the modifications, but I'm very happy with the overall results.
Old Sep 18, 2025 | 09:00 PM
I recently switched to slotted & drilled rotors and I’m trying to find 17in rear wheels but the bolt pattern is my dilemma but I plan to switch to carbon fiber seats as well…
Old Sep 18, 2025 | 10:00 PM
OzXFR's Avatar
You need 19" minimum front wheels to clear the front brake calipers, so putting 17" rears on (they should fit over the relatively puny rear brake calipers) would look a bit dopey!
Old Sep 19, 2025 | 07:36 AM
DJS's Avatar
DJS
His car started out as a base, so I assume he has 355mm in front and 18” would fit?
Old Sep 19, 2025 | 07:55 AM
Haalex's Avatar
If I may, there's a point where it makes more sense selling what you have and using your upgrade money on a different car.
Upgrades are expensive, and you rarely more than a marginal part of them when selling.
Before putting another 10 grand in the car, think about what you could sell it for and what you could buy with the sale + upgrade money
Old Sep 19, 2025 | 11:49 AM
no I have 380mm in the front & 325mm in the back that’s why I want to get 17” in the rear ONLY and stay with 20” in the front I want more tire on the rear
Old Sep 19, 2025 | 11:51 AM
this is my fun car I have several others, my goal is to build a sleeper v6 that looks OEM on the outside but is fully modded so I rather spend the 10-20k on building it since I know I’m not getting anything close to what I bought it for a year ago.
Old Sep 20, 2025 | 05:50 AM
Dionysus's Avatar
Hi @SuperchargedFresh
How are you planning to use this car?
Street car
Dragstrip
etc.
Best,
Old Sep 20, 2025 | 09:43 AM
Street car
Dragstrip
etc.
Best,
street & drag I enjoy racing in general
Old Sep 20, 2025 | 11:06 AM
Dionysus's Avatar
OK, got it.
Thanks,
Old Sep 21, 2025 | 06:41 PM
randyb's Avatar
S/C cars do not normally lend themselves to TQ, your best bet is to unload weight, especially off the nose. Go lighter seats and remove the dead weigh behind the seats.
Old Sep 22, 2025 | 09:00 PM
Obi's Avatar
Obi
Increase displacement, swap rods and pistons (consider using ones for the V8), custom fit a tvs 1900. Install a chiller system, use an octane booster, and have the car tuned for 96.
Or as other suggested buy a v8. To make a long story short, I was in your shoes a few years ago.
Had dual pulleys, wmi, tcu tune, forged rims, lithium battery etc.
Was in the middle of adapting the tvs 1900. Unfortunately (luckily) a deer killed my jag so I never finished... I bought a v8 instead
Assuming you can do most of the work yourself; should be within your budget. Biggest expense will be producing a one off intake manifold and intake runners.
There is a chance that the runners can be adapted as is, I was experimenting prior to moving to the v8. But if not you, can probably have a mold made of the runner and just change where the holes for the bolts go.
Old Sep 22, 2025 | 09:21 PM
dennis black's Avatar
weight reduction is a waste of time unless your chasing track time, .boosted rickey runs full interior and now going for 9 second quarter mile ,if its street use you wont even use most of that power ,but track you need weight reduction
Old Sep 22, 2025 | 09:42 PM
OzXFR's Avatar
Nup, you can't use V8 pistons in a V6 as the V6 has a smaller cylinder bore than the V8.
The V6 also has a shorter stroke than the V8 so you may or may not be able to use V8 rods with V6 pistons.
