Differential control module
Old Apr 13, 2020 | 12:33 PM
Terrance39's Avatar
Default Differential control module
Anyone know exactly where this module is located?
Old Apr 13, 2020 | 01:29 PM
Rummy636's Avatar
Luggage compartment below the floor trim in front
COMPONENT LOCATION - SHEET 3 OF 3 - ELECTRIC REAR DIFFERENTIAL - 5.0L V8 PETROL S/C
ITEM DESCRIPTION 1 Rear Differential Control Module (RDCM) 2 Electric rear differential
Old Apr 13, 2020 | 03:48 PM
Terrance39's Avatar
Anyone knows why the e diff requires programming if you change out the motor on the diff?
Old Apr 13, 2020 | 05:50 PM
Terrance39's Avatar
Thanks for that, do you also know where the all terrain module is as well?
Old May 29, 2020 | 09:32 PM
XKR100coupe's Avatar
If the connector is a "pass thru" , it needs to be checked. Had same on my Cadillac. Also if the wiring harness is near /rubbing metal anywhere it will cause the same. The reference wires are thin , and dont do well when touching grounded metal
Old May 29, 2020 | 11:05 PM
Ltrain925's Avatar
I just had my diff and output shafts changed and Jaguar reflashed my whole car to oem tune. Not sure why but they did it
Gerard
XJ40 ( XJ81 )
Feb 21, 2020 02:30 PM
03Xtype
May 16, 2016 09:57 PM
hafren
Aug 18, 2015 10:46 AM
arthurdaley
Jan 3, 2013 11:04 AM
Novo
Jun 27, 2011 08:22 AM
