Does anyone know if the Eventuri intake is legit?
Old Apr 5, 2017 | 08:27 PM
  #61
Unhingd's Avatar
Originally Posted by hoonery
How did you get to 7200 RPM? Is that an inaccurate reading? I thought 6800 was cut off.
Those intake temps and ambient air temps are really high. Guess it was a hot day.
ss23 has a tune.
Old Apr 6, 2017 | 06:34 AM
  #62
hoonery's Avatar
Originally Posted by Unhingd
ss23 has a tune.
Didn't know it raises it from 6600 to 7200. Sounds like a lot, no?
Old Apr 6, 2017 | 08:45 AM
  #63
Unhingd's Avatar
On mine the original limit was 6800 and I believe it is now 7000. Definitely needed with the MT, as I was always bouncing off the rev limiter. 6800 just isn't a sweet spot for a shift. 7k is perfect. An extra 200 rpm is not going to hurt. I'm not certain about 400.
Old Apr 6, 2017 | 11:22 AM
  #64
alphakinase's Avatar
RE: dyno graphs on post #45...
isn't this the first dyno we've had published on a V6 with both pulleys swapped, VAP tune AND 200-cell cats?
I know it's sacrilegious/impossible to compare dyno graphs but... are we able to see what effect the 200-cell cats have over unhingd's setup for example? (tune, both pulleys, stock cats).
Old Apr 6, 2017 | 11:53 AM
  #65
Unhingd's Avatar
Except for the 200 cell cats, ss23 does indeed have the same setup as I do, yet my Dyno results show 386 hp at the rear wheels rather than the top number of 352 for ss23. No reason why they shouldn't be similar. Testing really has to be done on the same machine for comparison purposes.
Old Oct 23, 2017 | 11:23 AM
  #66
sts-v's Avatar
Banned
Interesting. sgvkirbster saw 5hp gains with this intake.
https://www.jaguarforums.com/forum/f...lation-188729/
Old Oct 23, 2017 | 11:54 AM
  #67
sgvkirbster's Avatar
Hahaha. Actually it's about 7-9 HP. But yes, point being it made way less HP than advertised. So if you're expecting anywhere near the claimed 30 HP increase, you'll be disappointed. Perhaps if u dynoed on a DynoJet or even a Mustang Dyno MAYBE (emphasis on maybe), you'll see a more significant increase. However, the increase in HP is only at peak, not throughout the range. So whatever dyno u test it on, it will only show an increase around 6,000 RPM.
Old Oct 23, 2017 | 01:54 PM
  #68
sts-v's Avatar
Banned
Do you feel this intake could be replicated with some simple tubing and conical filters?
Old Oct 23, 2017 | 02:00 PM
  #69
SinF's Avatar
I can do even better - 7-9HP peak difference can be replicated by running dyno earlier in the day, when air is colder. No other mods required.
Old Oct 23, 2017 | 02:21 PM
  #70
15FTypeR's Avatar
I am only interested in increasing the supercharger noise.
Possible to just remove the resonator tube?
Old Oct 23, 2017 | 06:21 PM
  #71
sts-v's Avatar
Banned
This is also the only reason I'm interested.
Old Oct 23, 2017 | 07:01 PM
  #72
FR500GT's Avatar
Same
Old Oct 23, 2017 | 07:50 PM
  #73
OzXFR's Avatar
At least two other threads on increasing the F-Type SC noise, see here
https://www.jaguarforums.com/forum/f...ight=resonator
and here https://www.jaguarforums.com/forum/f...ight=resonator
Also several threads/posts on the same topic in the XF section.
To summarize, the Eaton TVS R series blower is designed to be quiet with very little "whine" and there isn't a helluva lot you can do to increase the whine enough to hear it over the exhaust.
Many have fitted after-market induction tubing kits (including me!) such as the TCP kit to their SC XFs (eg XFR) but the jury is out on whether that really increases the SC whine. I for one couldn't detect any real increase but others claim to have done so. There is no equivalent kit for the F-Type yet (the F-Type induction tubing is very different to the XF) although Mina Gallery have had one "in the pipeline" for several months.
A few XF owners have chopped off and sealed the Helmholtz resonators (L shaped protuberances) on the OEM intake tubes (3 on the XF, 2 on the F-Type) and claimed this has increased the SC whine a bit. You could try the same thing on the F-Type (see the schematic, item #9, in post #1 of the second linked thread above).
With all these XF mods I'm of the opinion that any actual or perceived increase in SC whine is really a slight increase in induction roar, as I struggle to see how modifying the intake effects SC whine.
Old Oct 23, 2017 | 08:01 PM
  #74
DJS's Avatar
DJS
Perhaps you could figure out how to modify the symposer. Wonder if this is still installed on current cars.
https://www.jaguarforums.com/forum/f...defeat-171035/
Old Oct 23, 2017 | 11:23 PM
  #75
lizzardo's Avatar
Modify the symposer? Disable it. See what you think. I'd forgotten how much I disliked it until you brought back memories. After I initially disabled it I bought a valve so I could manually switch it (manually, under the hood) but I never installed it because it I haven't missed it even the slightest bit. The sound is wonderful without that abomination.
Old Oct 24, 2017 | 12:27 AM
  #76
15FTypeR's Avatar
Modify the symposer. Or maybe disable it and the whine will be more audible without the symposer sending "other" sounds? I will have to seriously look into this. Thanks for the diagrams OZxFR
Old Oct 24, 2017 | 05:39 AM
  #77
sts-v's Avatar
Banned
How did you go about disabling it?
Old Oct 24, 2017 | 09:21 AM
  #78
lizzardo's Avatar
The link DJS noted a couple of posts ago was the thread I created to describe it. It only takes a few minutes and is completely reversible.
ltshaneclarke
Oct 23, 2018 06:24 PM
VinnyT
Mar 3, 2016 05:54 PM
SRL1990
Feb 15, 2016 05:01 PM
StealthPilot
Feb 14, 2016 08:20 PM
larbear
Feb 9, 2016 02:02 AM
