Does this SC coupler/isolator needs repair? (video)
Old Mar 31, 2025 | 12:12 PM
J444G's Avatar
Default Does this SC coupler/isolator need repair? (video)
I am in the middle of the pipes work and I am not sure if this is a bad coupler or not. My car has no rattles, only 1 clunk on engine off which I thought is normal.
There is a small 1-2 millimeters play with little force needed to turn, then the SC starts to move.
video: https://imgur.com/a/eNfYKao
Thank you!
Old Mar 31, 2025 | 02:06 PM
JagCode3's Avatar
@J444G Thanks for posting - you are an inspiration to all us DIY'ers about to tackle this!
The SC play you have I believe is normal with the original spring coupler. However that play can grind down the shaft. I would check the shaft for wear while you have it out.
Check out @waldo's installation of the solid ZZP coupler and the shaft wear he found:
https://www.jaguarforums.com/forum/f...5/#post2794271
Old Mar 31, 2025 | 02:17 PM
J444G's Avatar
Thanks, well, I kinda don't want to open the SC if I don't have to to be honest, because there is a hassle with the silicon, and even if I open it I don't know if it is bad or not...
Old Mar 31, 2025 | 02:51 PM
JagCode3's Avatar
Agree @J444G there's enough to do already. I think the consensus now is the OEM torsional coupler is preferred over the solid.
Old Apr 1, 2025 | 07:58 AM
Carbuff2's Avatar
What is the hassle?
Is the supercharger top cover sealed with a silicon?
Asking for a friend.
Old Apr 1, 2025 | 08:21 AM
J444G's Avatar
Originally Posted by Carbuff2
What is the hassle?
Yes it is, and I am unable to say if the coupler is fine anyway..
Old Apr 2, 2025 | 02:45 AM
J444G's Avatar
I have asked superchargersonline about it and they say 1-2mm play is normal, so I guess I am fine?
Old Apr 2, 2025 | 07:44 AM
Carbuff2's Avatar
What is the hassle?
Yes it is, .
Well, actually it isn't/shouldn't be...the OE gasket looks like this..
Funny, when I called around looking for one, a NAPA guy said "Do you want the RTV sealer instead?
Old Apr 2, 2025 | 07:59 AM
J444G's Avatar
I thought we are talking about the snout silicone gasket to get the isolator...
Old Apr 2, 2025 | 09:19 AM
Carbuff2's Avatar
Sorry for the Topic Drift!
Old Apr 2, 2025 | 09:31 AM
JagCode3's Avatar
@J444G Carry on with your repair. We are learning much from your journey. Your SC snout is all good.
Old Apr 2, 2025 | 07:32 PM
OzXFR's Avatar
Good video about replacing the SC coupler (and other things):
Yes, I know, it's a 2010 XFR (almost identical to my old 2010 XFR, same Kyanite blue!) but still the same AJ133 SC as in the F-Type (save for some very minor revisions since 2010).
They show how hard it is to get at the coupler and why the SC needs to come right off to do the job.
Also Tom Lenthall, one of the most knowledgeable and experienced Jag tuners/mechanics on the planet explains how an SC driveshaft that has been chewed at by a dodgy coupler is not a problem.
Spoiler alert - just after they stitch it all back together and give it the beans the dreaded timing chain stretch/slip strikes and grenades the engine.
tcsamir21
Jan 5, 2023 06:08 AM
powerhouse
Jul 26, 2015 10:46 PM
kblaw
Sights N Sounds
Jul 19, 2013 09:39 PM
gragner66
Photography
Jul 7, 2013 08:57 AM
