Door Panel Fit
Old Sep 28, 2018 | 02:52 AM
markjord's Avatar
Default Door Panel Fit
Hi. Just got my beautiful F Type. I’ve read a lot about poor panel gaps and I notice that my driver’s door (right hand drive) sits proud of the rear panel. Passenger door is fine. Can this be adjusted?
Old Sep 28, 2018 | 03:21 AM
OzXFR's Avatar
Yep.
On the panel next to the door is a large U shaped hook / door catch, held on by two largish Torx screws (T40?).
Loosen those screws and push the catch in a couple of mm, then do the screws up until the catch is reasonably tight, then shut the door and check the gap.
Keep adjusting until the gap is perfect, then do the screws up nice and tight.
Old Sep 28, 2018 | 03:37 AM
markjord's Avatar
Thanks. I wonder if I should get the dealer to do it in case I cause a problem then they say it’s down to me. Or am I being too cautious?
Old Sep 28, 2018 | 03:40 AM
OzXFR's Avatar
As long as you have the correct size and shape torx bit it is easy, just be careful you don't slip and scratch anything and make sure the screws are done up good and tight when you are finished adjusting.
Old Oct 1, 2018 | 02:55 AM
Greggbhill's Avatar
both of mine went back to dealer for minor adjustment to panel fitment. No hesitation by dealer, almost as if expected. One thing to think about is there is a limited time on warranty for fitment issues - can’t remember exactly where I saw it or was told, but worth asking about to avoid surprises.
Old Oct 1, 2018 | 09:20 AM
WJV's Avatar
WJV
This. Mine also had some minor fitment issues, primarily with the interior, and the dealer was quick to resolve. They seem to expect a certain degree of inconsistencies with regard to panel and/or trim fitment. I think as long as the vehicle is still under the original warranty period, the dealer will honor fitment adjustment requests w/o pushback.
Old Oct 1, 2018 | 11:10 AM
markjord's Avatar
Let’s hope they can make mine right. Thanks guys.
jomo
Aug 22, 2014 04:51 PM
RSpi
Jan 21, 2014 10:21 PM
H20boy
Aug 25, 2012 05:45 PM
TomServo
Jan 18, 2012 05:10 PM
jagosaurus
Aug 23, 2011 03:10 PM
