dynamic mode launch control
Old Dec 8, 2015 | 03:04 PM
Foosh's Avatar
Dynamic, automatic, and traction control on.
Old Dec 10, 2015 | 11:56 PM
Pascobob's Avatar
Default yes
that is exactly my question without launch control what is the best approach to zero-60 with minimal wheel spin. I am thinking the snowflake mode may work. If you get an answer please let me know. Thank you
Robert.imperato@saintleo.edu
Old Dec 11, 2015 | 04:48 AM
Unhingd's Avatar
Snowflake mode introduces all kinds of throttle management. I wouldn't be surprised if that more than doubles your 0-60 times.
Old Dec 11, 2015 | 06:48 AM
Schwabe's Avatar
auto, dynamic mode, start light gas and whale on it when you feel it hooks ....
here they do 3.6 secs with explanation ...
Old Dec 11, 2015 | 12:04 PM
Pascobob's Avatar
Default thanks
Thanks. Your response was super helpful. I was out on some country roads today and that's what I ended up doing: light on gas until I felt traction and then I nailed it. Your comment is confirmation that I have been looking for. I have an autocross day Sunday and what you say will pay off. Thanks again.
I am not used to such a powerful car. My other car is a Lotus Elise and I know exactly what it is going to do in most circumstances. I'm just discovering what this F type R will do. I was glad to discover today that even with tire spin the car does not swerve (on dry road).
Thanks again.
Old Dec 11, 2015 | 12:08 PM
Pascobob's Avatar
one more thing. When you say "auto" are you recommending that I not shift but let the car shift itself?
Old Dec 11, 2015 | 12:17 PM
Foosh's Avatar
Yes, let it shift automatically. Dynamic mode automatically raises the shift points for max acceleration.
Old Dec 11, 2015 | 12:34 PM
  #28
Pascobob's Avatar
Default thanks
So I put it in "dynamic" [checkered flag] and leave it in drive[ D]? Would that be optimal for autocross? I am so used to shifting that I never leave it in Drive, just checking. Thank you
Old Dec 11, 2015 | 01:00 PM
Foosh's Avatar
It really depends upon how tight the course is. On a tight course with very short "straights," you might be in 2nd gear virtually the entire time and dynamic/manual might be quickest.
I've also done a lot of autocross in both a Lotus Elise and a C6 Z06. I'm used to manual shifting as well, but I suspect the F-Type might be quicker in dynamic and automatic. The ZF auto is very good at picking the right gear based upon rpm. If it were me, I'd do a lot of experimenting both ways.
For straightline acceleration, and on most road courses, I think the car would end up being quicker in automatic, but in all cases put it dynamic mode.
Old Dec 11, 2015 | 01:05 PM
  #30
Pascobob's Avatar
Default grazie
Sounds right to me. I suspect I won't get out of 2nd gear. If I have enough chances, I'll try both automatic and shifting. With automatic I'll be able to focus on steering a bit more. I'm just not used to trusting automatic; this will be a learning experience. Thanks for your comments.
Old Dec 11, 2015 | 04:18 PM
  #31
TXJagR's Avatar
While I totally agree about Dynamic mode, AND letting the car shift itself, I'd put it into S instead of D.
Sport + Dynamic seems to be the highest amount of performance. S also raises the shift points a bit higher than just Dynamic. You actually might not shift at all on the entire AutoX course. It's highly probable that you'll always be in second.
Old Dec 11, 2015 | 05:13 PM
  #32
Pascobob's Avatar
Default I wish you could hear me chuckle
The fact is shifting is fun! My hunch the time difference will be nearly negligible.
The F Type is not the fastest car but it is one of the most fun. I need to have fun sub 80 miles an hour, and the sound does the trick. Thanks again for your input.
Old May 1, 2016 | 07:53 AM
  #33
Dogbreath!'s Avatar
I finally tried it several times yesterday. No luck. My conclusion is MY14 V8S does not have it.
Old May 1, 2016 | 08:01 AM
  #34
Unhingd's Avatar
I don't think any of the V8 cars have launch control. They have plenty of power to spin the rear tires without raising the stall speed on the torque converter. I believe that was a feature on the AT V6 cars only.
Old May 3, 2016 | 01:04 PM
  #35
Schwabe's Avatar
no launch in V8 cars, too much torque ... I know there are cars with this much torque and launch but they usually have AWD with even 50/50 distribution and a dual clutch and not an auto. To have launch in the V8 they would need a different transmission for sure or your transmission and clutch would stay behind at the starting line ....
Evan Trinh
87
Sep 24, 2018 05:44 AM
Naso--Lituratus
Jan 31, 2017 06:01 AM
Donk
Jan 25, 2016 10:16 AM
heroooo
Dec 9, 2015 07:17 PM
natwal
Dec 4, 2015 11:24 AM
