Dynamic Side Mirror Sequential Light For Jaguar
Old Feb 14, 2021 | 08:26 AM
powerhouse's Avatar
Default Dynamic Side Mirror Sequential Light For Jaguar
Anyone fit these,
Old Feb 14, 2021 | 09:05 AM
Cirving's Avatar
I installed a set a month ago, easiest job I’ve ever done! They look good, brighter, sequential and a smoked look when off which blends into the mirrors better
Old Feb 14, 2021 | 09:35 AM
powerhouse's Avatar
Did you take out mirror glass or just detached the mirror cover, where you purchase yours
Old Feb 14, 2021 | 09:44 AM
Cirving's Avatar
I just pulled the cover, (2015 if it matters) it was 10 minutes for the first side and about a minute for the other side once I knew what I was doing. I found them on eBay, it took a couple of weeks to get them though
Old Feb 14, 2021 | 11:46 AM
powerhouse's Avatar
Anything to just be careful with removing the covers have seen some videos and resulting broken clips
Old Feb 14, 2021 | 12:01 PM
Cirving's Avatar
I used the tool they sent with lights and the cover pops right off, just be careful!
Old Feb 15, 2021 | 04:50 AM
wurldfamuz's Avatar
I got them back in July of last year, i posted asking if anyone knew about it and not one responded. I actually ended rup eaching out to one of the vendors/manufacturer from China that I had purchased a set from for my S4 a few years ago and they told me they were actually in the process of putting them out in the market. I couldnt be more excited, its a very subtle modification that most people wouldn't even notice, but I think its great.
Old Feb 15, 2021 | 08:11 AM
Clutch's Avatar
I like this mod a lot. Regarding the tool they sent and removing the housing in general - besides being careful not to break any clips, is there any kind of gasket or seal there that needs to be replaced or re-furbed before putting the housing back on?
Old Feb 15, 2021 | 11:27 AM
schuss's Avatar
Has anyone compared them side by side, are they actually brighter? I've seen a lot of these that are a little subdued in person. They look very cool tho.
Old Feb 15, 2021 | 09:15 PM
Borbor's Avatar
I don't mind this mod at all as it is cool but as I am not going to be able to see it myself there is no point in doing it
It might be cool for other drivers but as f type are so rare they will be looking at the rest of the car and probably not notice you have sequential indicators.
So it's really only there for other f type owners to notice and theres nothing wrong with that.
Old Feb 15, 2021 | 11:17 PM
wurldfamuz's Avatar
clutch - there's nothing to it. you can actually remove the mirror cover by squeezing it little and pulling down on it with 2 hands and it should just pop right off and as far as the light theres nothing to unplug the harness and remove 3 screws and then plug the new ones on and put the screws back on and the cover just snaps back on.
Old Feb 15, 2021 | 11:20 PM
wurldfamuz's Avatar
I think the light is just as bright as the factory OEM ones, the only difference is it blinks sequential
Old Feb 15, 2021 | 11:23 PM
wurldfamuz's Avatar
of course theres going be difference in brightness side by side since factory light flashes all at ones and the dynamic version flashes in sequential pattern but by themselves the dynamic ones are just bright as factory.
Old Feb 16, 2021 | 11:31 AM
powerhouse's Avatar
So order a set today off eBay so can't wait to get on, wurldfamuz so the glass doesn't need to be removed just pull the cap straight off, can you elaborate on the removal of the cap , squeezing it little? not sure what you mean about that , then pull down.
Old Feb 16, 2021 | 01:00 PM
sov211's Avatar
You just press (squeeze) the top edge down a bit to get it to release. At that point the removal becomes obvious. No tool necessary...I have done it a number of times.
Old Feb 16, 2021 | 01:03 PM
powerhouse's Avatar
thanks so no need for glass removal
Old Feb 17, 2021 | 03:13 PM
sov211's Avatar
Absolutely no need to touch the mirror glass itself.
Old Feb 17, 2021 | 06:47 PM
GeorgeIII's Avatar
You just might want to view the video on #1 post.... will walk you right through the process.
Old Feb 19, 2021 | 08:49 AM
Clutch's Avatar
Has anyone seen these in "clear", (like originals) not smoked? I think I would prefer that but all my searches turn up smoked ones.
Old Feb 19, 2021 | 01:35 PM
powerhouse's Avatar
Haven't received mine yet but because there smoked I presume that's why they stand out more when on, clear just wouldn't .
