Easiest way to improve sound? (No active exhaust).
I hope you're right. I'll give it a shot tonight.
That is incorrect information. F43 will have a fuse even without the active exhaust. Sometimes its cheaper for companies to build one version of a fusebox rather than having multiple versions.
My first F-TYPE base (along with other numerous ones I have access to) all had a fuse in F43 even though it didn't have an active exhaust system. Best way to check is to see if your car has the valves.
Varies with year and market. If you don't have an active exhaust it may seem louder all of the time than the active exhaust does when being quiet. Which is no bad thing, unless you have a complete bunch of < > on the committee of your HOA.
But this is why you have 1st and 2nd Amendment Rights. Yes?
I am very sure the base model does not have the baffles. I'd recommend the Velocity mufflers. They look like a direct bolt on and interchangeable but don't take my word for it. They offer them in "Touring," "Sport," and "Super Sport." Be careful, because you can't change the sound on these.
Jaguar F-Type Sport Exhaust Touring Sound Level
Also, here is a base V6 with Quicksilver exhausts:
https://quicksilver-exhausts.glopal....exhausts.store
Last edited by Jagged Wire; Jul 29, 2017 at 05:41 PM. Reason: left out a word and added content
I have a base model, its done 50k and its loud enough, I think the coupe is pretty tame with the windows up but with the windows down and higher rev's it defiantly sounds sweet enough.
If you want to test the sound, if you switch to manual and rev in second gear to around 5-6k then let go of the accelerator the car will make that amazing machine gun popping noise.
It does do this in auto but its more forced in manual, I did have a dilemma of switching to a louder exhaust but feels its enough now I owned the car a few months.
if in a tunnel or car park give it some throttle and you will hear the tones bounce all off the walls very immature but wonderful at the same time
This shows what the active exhaust components look like - it's from 2014, so don't know what's changed. At some point, they deleted the vacuum pump and ran a vacuum line back from the engine compartment (MY17?)
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
I'm always excited when I find a tunnel or long overpass, and my immature 17 year old inner self pulls the shifter into sport, downshifts, and floors it to hear the glorious symphony... unless my wife is with me because she just gives me that "you're amazingly immature" look:-)
I checked my exhaust against @Greggbhill's Jag with active exhaust and mine is missing the solenoid. So I guess fuse F43 doesn't really do anything.
On the road, the active exhaust is a bit louder and pops a bit more often. Still what forums said I think is accurate: the non-active exhaust is closer to the active exhaust turned on than turned off.
All manual F-Types come with active exhaust. Don't know why it doesn't come with standard with automatics. It would be nice if all F-Types came with the active exhaust.
