Engine blown?
Old Aug 27, 2020 | 08:07 PM
Justin60098's Avatar
Default Engine blown?
I was sitting at a red light and started hearing a noise, I pulled over and checked it out. Sounded like a loud cranking metal on metal noise. After further investigation I was surprised to hear a valve had dropped. What should I do? New engine? Rebuild?
Old Aug 27, 2020 | 08:12 PM
gg2684's Avatar
Seems like more info would be needed to make a recommendation. At the very least, I would have the noise diagnosed before before deciding on a rebuild or new motor.
Old Aug 27, 2020 | 08:29 PM
It would probably be good to know what model the car is also.
Old Aug 27, 2020 | 08:42 PM
Stohlen's Avatar
Who's investigation? Did you pull a valve cover/open the intake?
Old Aug 29, 2020 | 09:40 AM
SinF's Avatar
Before you assume catastrophical damage, take time to investigate.
Anecdote - one time I was convinced I was hearing crankshaft bearings, something I heard before on other engines and know how it sounds well, when the issue ended up belt tensioner pulley.
Kev-P-
Jul 3, 2020 09:37 AM
blindside
Sep 9, 2019 03:15 PM
omgimali
Aug 11, 2017 06:44 PM
vincent661983
Sep 29, 2014 05:46 AM
reyesl
Mar 19, 2014 09:13 AM
