Engine code/exhaust issue solved
Old Oct 17, 2022 | 03:19 PM
pab74's Avatar
Thumbs up Engine code/exhaust issue solved
Exhaust tone/P2404 fix
Have submitted a couple of post in the last two weeks about various issues with my F-type. Overall, the exhaust tone and the car just did not feel right. Slight loss of power/throttle response
Engine light (P2404) Emission (Turned out to be a faulty gas cap) Replaced zero code since.
Exhaust tone not as prevalent/pops and bangs less often (Removed exhaust vacuum pump/TSB/replaced exhaust vacuum that connects to exhaust. Exhaust is back to normal
Parts list
Part Number Part Name
T2R19086 Vacuum Hose
AJ812350 Vacuum Hose
AJ811695 Purge Control Valve
T2H46581 CAP-FUEL FILLER
AJ813949 Vacuum Hose
Although all the parts listed may not have needed replacement, I could not pinpoint the leak with soap and water or want to pay a shop to figure out the issue. In the end the car is running great and has for the most part a completely new vacuum path.
Old Oct 18, 2022 | 05:51 PM
Valerie Stabenow's Avatar
Default the parts and the process
Would this issue pertain only to your model F? I have a 2017 base, premium, but like to keep it in good order.
I have a new cap, and I did check under the car to make sure the hoses were on the valves (stems)
Is the AJ811695 Purge Control Valve complicated to replace? I'm pretty handy with repairs, ( had 5 old british cars and since 1989 an E type that I work on.)
thank you,
pab74
Oct 15, 2022 06:28 AM
pab74
Oct 2, 2022 08:52 AM
eeeeek
Aug 16, 2019 07:41 PM
Jlgti
Aug 22, 2017 08:00 PM
