Engine shuts off on its own?
Old Feb 2, 2018 | 09:49 AM
Tim Lee's Avatar
Question Engine shuts off on its own?
Hey Folks, I've had my F-Type for about 3 months now, only have put 600 miles on it due to weather. I haven't had any issues so far but there were two instances where I reversed the F-Type into my garage and shifted to Park, before I can even press the Engine Start/Stop button, the car just shut itself off for me. It's really odd and it has happened twice. When it happened, I started the car again and everything seemed fine.
What can cause this issue? Should I be concerned?
Tim
Old Feb 2, 2018 | 10:10 AM
ek993's Avatar
Eco stop / start?
Old Feb 2, 2018 | 10:13 AM
Tim Lee's Avatar
Originally Posted by ek993
Eco stop / start?
Thanks for the reply, but eco stop/start just shuts off the engine. In my case, the whole car shut off as if I pressed the engine start stop button after I shifted to Park.
Old Feb 2, 2018 | 10:47 AM
DJS's Avatar
DJS
ECO will do this if you take off your seatbelt before turning off the ignition, while ECO is on. If I'm in the middle of putting the roof up, the roof stops, and I have to start the engine (not just turn on the ignition) to finish putting the roof up. In this case, ECO seems to do a harder shutdown than just turning off the ignition.
Old Feb 2, 2018 | 10:55 AM
Tim Lee's Avatar
This might be it! I will test it out again today and see if I can duplicate this.
Thank you very much!
Old Feb 2, 2018 | 04:27 PM
lizzardo's Avatar
I'm sure that's a safety feature. Don't want to walk away from a vehicle that is on, but engine not running. A restart might lead to tragedy.
Old Feb 2, 2018 | 04:42 PM
dmchao's Avatar
If you are in eco, like mentioned before, and unbuckle your engine will turn off in park. I actually quite like that.
Old Feb 3, 2018 | 09:42 AM
caviarjag's Avatar
Agreed that is a nice feature. i rented a 7 series when I was in Austin several years ago that was my first start/stop car and on more than one occasion would forget to turn the car 'off' after I put it in park because the engine had already turned itself off. Could not for the life of me figure out why it would not lock. Also weirded me out the first time my ftype shutoff on me. Mine is a manual and I thought I had somehow stalled the car sitting still. Now it's routine to shut that off first thing on startup.
Old Oct 17, 2018 | 10:10 PM
SS4PK's Avatar
Agree, our Range Rover will shut off like this when you unbuckle. I can't remember the exact way it does it but that is definitely what is going on damn Eco BS
Old Oct 18, 2018 | 11:55 AM
Morgan52's Avatar
It will also happens if you open your door.
Old Oct 18, 2018 | 07:48 PM
Unhingd's Avatar
None of this appears to afflict the cars with an MT.
Old Oct 18, 2018 | 11:32 PM
NoScurdyJags's Avatar
Actually, its happened to me as well, the first few times had me scratching my head because I was sure I didn't stall the damn thing. I did end up confirming that it was because I had forgotten to turn off the stupid start/stop feature.
Old Oct 19, 2018 | 06:42 AM
Unhingd's Avatar
Mine certainly turns off/on, but opening the door has no impact on it.
Old Oct 19, 2018 | 10:55 AM
eeeeek's Avatar
What if you open the door while in gear?
Old Oct 19, 2018 | 01:21 PM
SinF's Avatar
I remember seeing a gag video, where someone put a remote starter on a MT car, leaves it in gear and then tried to start. It was entertaining, as the car got away and even shifted into second gear as it was accelerating away... that remote starter was just that good.
Old Oct 19, 2018 | 01:52 PM
vika01's Avatar
Effspot talked about this weird issue in a video.
Old Oct 19, 2018 | 02:51 PM
NavyBlue's Avatar
Search for thread to disable Eco start/stop.
I was hesitant.
But once I took the 5 min to pull the plug, it's been wonderful since...
Old Oct 19, 2018 | 09:10 PM
That's really odd! It just did it for me a few minutes ago. I left work, did not disable start/stop as I was going to the gas station that's about 1 minute down the street, pulled into the gas station, car was on, opened door to get out, realized my windows were down but before I knew it, the car had shut off. I had to press the ignition button to get it into accessory mode to close my windows. My 6MT definitely does it, I wonder if maybe that feature was left out of your tune?
Old Oct 20, 2018 | 03:50 AM
Unhingd's Avatar
Yeah...I don’t think so. Good one. lol
Old Oct 20, 2018 | 03:55 AM
Unhingd's Avatar
I’ll give it a try.
I would have thought that the ECO logic would have been part of a totally different logic module.
