Engine swap
Old Mar 30, 2025 | 10:14 PM
Toobadt's Avatar
Default Engine swap
From what I have discovered searching my 2015 f type v6 dealer history it received a 7000 mi engine replacement for the failed engine in 2019 with only 29k Hence the newer coolant pipes I had noticed. The report says the engine failed and was replaced under warranty $8950. My question is how can I determine the man year for the newer mill and its specifics. All is well currently as the car now has 35 k .
Old Apr 2, 2025 | 08:09 PM
Zen Beer's Avatar
you could try to look up the number on the block (doubtfull), but if it was dealer replaced it should be in the service history. If it was a used engine (7k) replacement it wasn't from the dealer though to my knowledge. All V6's were the same it was simply software that affected the HP. If it was a used engine whoever sold it should have supplied paperwork with the vin the vehicle it came from. If I misunderstood the 7k piece apologies.
Lycaon
Feb 27, 2023 12:11 PM
Banes333
Nov 2, 2021 10:41 AM
ozbot
Oct 6, 2021 01:32 AM
PatJags156
Jul 2, 2018 01:08 PM
