Engine throwing code P026A Charge Air Cooler Efficiency Below Threshold
Old Oct 11, 2020 | 11:16 PM
taimysho0's Avatar
Default Engine throwing code P026A Charge Air Cooler Efficiency Below Threshold
Just noticed this error code popped up when I connected my scanner tool to the ODB connector. I have noticed coolant smell after driving the car in the garage, no white smoke from the tail pipe though. I did check the coolant level and it is slightly lower than "min". Should I be concerned or just top off the coolant reservoir? The smell is concerning but i dont think its a blown head gasket -- no leaks that i can see and there doesnt seem to be oil in the reservoir tank either. Appreciate any thoughts.
__________________
2014 F-Type V8 (added by GGG)
Old Oct 12, 2020 | 01:56 AM
Thoughts, yes.
Might be helpful if we knew which Jag is going hissy.
Old Oct 12, 2020 | 02:39 AM
There's a reason we ask everyone to add vehicle details to their forum signatures. I added 2014 F-Type V8 to yours.
P026A is a defined dignostic code for the Jaguar Ingenium Diesel engines. However, I have the 2014 V8 engine in my XK and it is not a defined code for that engine. A typo or using an incompatible code reader?
As for the coolant level, overheating is an engine killer on the Jaguar V8 and you should investigate any loss. As a minimum action, the level should be topped up immediately. Small leaks are often difficult to find and a pressure test can help troubleshooting this.
Old Oct 12, 2020 | 10:51 AM
taimysho0's Avatar
sorry about that! im a noobie to the thread, and yes this is for 2014 f type v8. appreciate the help!
Old Oct 12, 2020 | 01:54 PM
I've moved your question from General Tech Help to F-Type forum for advice from members with the same model.
Angel Guillermo
Apr 30, 2022 01:48 PM
patrickw813
Dec 8, 2018 11:36 AM
ChrisJay
Apr 18, 2017 06:31 AM
magpie
16
Oct 27, 2016 05:32 PM
Rique
Oct 18, 2016 09:48 PM
