experience with Mina Hood Spears
Old Sep 14, 2021 | 12:17 PM
SteveHall's Avatar
Default experience with Mina Hood Spears
Has anyone purchased the Supercharged hood spear finisher set: Jaguar F-Type "Supercharged" Hood Spear Finisher Set - Mina Gallery Inc ?
Can anyone comment on product quality and fit?
Steve
Old Sep 14, 2021 | 02:50 PM
YRS's Avatar
YRS
Hmmm, they look pretty darned good too.
Old Sep 16, 2021 | 04:47 PM
koolkat's Avatar
I purchased a set this last Febuary, took a little while to get but they are beautiful! Fit is perfect although I wish there was a gasket to go with them.
East to install, I used a hot glue gun to lock the little nuts that hold them in place. They even set the lettering up in red at no charge for the delay!
Old Sep 17, 2021 | 08:12 AM
datriani's Avatar
I have a set of matte black spears and they seem to be pretty well designed and constructed. I received them within a few weeks of ordering and I've had it on for about 3 months now. The finish is very nice and professional. The build is solid and doesn't flex easily. You can feel a significant amount of heat coming out of the vents after a drive so it's definitely doing it's job. It does open up that area to more water/rain coming through but the rubber covers over the shocks keeps that area dry. They are a bit pricey but probably a fraction of what Jaguar would charge if they designed and sold something similar.
I would 100% buy them again.
Old Sep 17, 2021 | 08:21 AM
datriani's Avatar
Here’s the backside view. As Koolkat mentioned , a rubber gasket would have been nice.
On the front side, I asked Mina Gallery to remove the strip that says "supercharged" so it's only the frame and mesh wiring.
Old Sep 17, 2021 | 08:24 AM
SteveHall's Avatar
thanks! very helpful. Agree that a gasket (or a bead of silicone) between the vent and the hood would be a good idea.
Old Sep 19, 2021 | 10:29 PM
GeorgeIII's Avatar
I really like my set. I started out with glossy black but then switched to the stainless steel. I also agree that a gasket of sorts should be included but I made my own and it worked out great.
Old Sep 19, 2021 | 11:23 PM
OzXFR's Avatar
The hood vents on my old XFR rattled a bit so I took them off and applied some thin double-sided tape, worked a treat.
Same with the F-Type (although they didn't rattle), I took them off to Dremel out extra ventilation air holes then put a few small strips of tape on when I re-fitted them.
Just take extra care to cut the tape thin and "tuck it in" so it doesn't show around the edges of the vent.
Syb Drylst
Jun 10, 2022 09:36 PM
joedinfl
Mar 18, 2020 12:36 PM
tberg
Mar 12, 2017 09:13 PM
jaguar jon02
E type ( XK-E )
Nov 17, 2014 01:17 PM
ProlixArgon
Apr 22, 2013 11:09 AM
