F-type 2014 navigator's map blacked out
Old Jul 14, 2024 | 12:52 PM
PATRICK78's Avatar
Default F-type 2014 navigator's map blacked out
Hi
I am in France in Paris and I bought a Jaguar F-TYPE R of 2014 which comes from the USA and I bought a USB key with the transformation of the card USA towards Europe.
All the installation went well but after the restart the GPS works with voice but I have a screen without map.
I've tried everything by disconnecting the battery for a whole night but I can't find the map.
Do you have a solution to help me?
I called Jaguar in France but they don't know how to help me.
However, I have seen on the Jaguar forum that several people have encountered this problem following updates or VAPs.
Thanks for your help
Patrick
Old Jul 14, 2024 | 01:34 PM
Turko's Avatar
Default Question for you .....
VAP. ??????
what do you mean when you indicated VAP.
what is VAP.
Please elaborate for us.
Thank you
Old Jul 14, 2024 | 02:08 PM
PATRICK78's Avatar
Hello
VAP is an update of the engine mapping with mechanics to make Jaguars more powerful.
all I did was update the US GPS map to the European GPS map
Patrick
Old Jul 14, 2024 | 02:17 PM
Turko's Avatar
Default I thought so ......
Originally Posted by PATRICK78
Hello
Patrick
When you mentioned VAP, the software upgrade tuning business came to mind immediately but I wanted to confirm instead of guessing.
So are you saying the VAP tune messed up your car's electronics and or the software.
Please share your thoughts for us.
Thank you very much
Old Jul 14, 2024 | 05:02 PM
uncheel's Avatar
I'm hoping the USB you mentioned is one for European maps. If not, that's what you need. On a MY14, the USB needs to be coded for your VIN number (otherwise, everyone could update their map from a single USB). The map update on older models takes several hours to load with the car running. From memory, I think it takes about 3 hours. (Ironically, it works best if you are taking a long trip, but you know where you're going, so you don't need the Nav.)
If all that is set, I would have suggested a hard shutdown (engine off, lock, wait a couple of hours), but I think your overnight disconnect should have covered that.
Last suggestion would be to check the video cable that runs from the head unit at the rear of the center console to the touchscreen.
Old Jul 16, 2024 | 03:47 AM
PATRICK78's Avatar
Default Black out gps jaguar f-type 2014
Hello,
Thank you for your reply.
I did buy a USB key that converts the US GPS to the European version.
In the end, after 3 hours of driving without stopping the engine, all the loading went well and I entered a code that was provided by the seller of the update according to my VIN.
But then I had to restart the car and the GPS found my city and location, but when I entered a destination, the voice worked but I didn't have a map.
Old Jul 16, 2024 | 06:56 AM
Turko's Avatar
Default Patrick .....
Hello Patrick,
You never did answer the VAP question. We'd like to know how the VAP engine ECU software could or would impact your car's navigation system and it's electronics with software.
Thank you
Old Jul 16, 2024 | 08:12 AM
PATRICK78's Avatar
Hi
I have never done a VAP on my car but in the forum several people have lost the GPS map either like me after a map update or after having done VAP modifications on their F-TYPE so I was asking if people have managed to find the GPS map and if so how did they do it.
I haven't found any solution yet.
Old Jul 16, 2024 | 09:29 AM
Turko's Avatar
Default Thank you Patrick .....
Good to know that doing an ECU engine software update can possibly cause other software/electronic related problems. Something to seriously consider before pulling the trigger on an aftermarket ECU software upgrade. Thanks again !
I'm surprised VAP never addressed this issue.
Old Jul 16, 2024 | 09:46 AM
Thunder Dump's Avatar
I've never heard or seen a verified report of a VAP tune affecting anything other than ECU/TCU. If someone can point to a post here or on another forum I'd like to see it. Correlation doesn't equal causation.
Old Jul 16, 2024 | 11:32 AM
PATRICK78's Avatar
Hi Thunder Dump
Hello
It's in your forum that some people talk about electronic or card or radio problems after using the VAP or after a card update.
I haven't done it, but I'm asking everyone if they've encountered any problems after a GPS map update or VAP loading, and above all if and how they were able to solve them.
I've never said that using the VAP could upset the car or the electronics.
Let there be no misinterpretation.
Old Jul 16, 2024 | 12:02 PM
clubairth1's Avatar
Community Influencer
I have been VAP tuned for several years with zero problems?
One question a bit off topic but I also have a 2014 (Different in that it's an XJ). What are doing for map updates? Jaguar died back in 2020 so the maps are getting out of date. No way to update now that I can find?
Old Jul 16, 2024 | 12:22 PM
Hi Thunder Dump
Hello
Can you provide a link to a thread here that specifically mentions applying a VAP tune affected their infotainment system?
Applying a tune via the OBDII port to the ECU/TCU, which does not touch the telematics/infotainment system at all, and updating a "card" (assuming you mean SIM card) which directly interfaces with the telematics/infotainment system are two very different things. I've never seen any reference to the former, but I've seen plenty of people reporting some type of connectivity or mapping issues when replacing a SIM or updating the infotainment software.
Old Jul 16, 2024 | 03:00 PM
scm's Avatar
scm
Are we getting confused between a map for navigation and an ECU map for a tune?
Old Jul 16, 2024 | 08:05 PM
Borbor's Avatar
A VAP tune isn’t going to affect nav MAPs or other systems as it is not writing anything there. I guess the only way is if you are poking around altering code/files with Pathfinder but that is entirely different to what you are implying
cat_as_trophy
Jul 9, 2022 01:58 AM
nicolaimoeller
Jul 26, 2021 06:25 AM
shift
Nov 18, 2014 12:59 PM
Scott Bourne
Jun 3, 2013 07:06 PM
Jaguar Forums Editor
May 23, 2013 07:00 AM
