F type AWD front Tyre inner wear
Hi everyone.
The car : 3.0 awd 2019
problem - front wheel inner wear , factory pirelli p zero . 60.000 km
the guy who made wheel alignment today , told that everything is in green position, but wheels camber is at maximum value. Like - next time I will need to find problems in suspension.
somebody posted here , that the guy from JLR gave him a different wheel alignment numbers , anybody can help me with this problem. Thanks in advance.
When we acquired our 2014, the inner edges of the front tires wore to the cords after 20,000 miles. We pointed this out to the alignment technician, who set the alignment to minimize this. (negative camber can aid ultimate handling). The alignment 'guy' followed our direction, and now the difference in tread depth inboard>outboard after another 20,000 miles is negligible. We do not track our F.
In fairness, I should mention that we replaced the original 200-treadwear P-Zeros with 500-rated UHP all weather 'shoes'. But as I said, I have monitored how they are wearing, with a tread-depth gauge at yearly oil changes.
A GOOD alignment shop should be knowledgeable enough to set the adjustments within the specifications to achieve your goals. NOTE that some cars are spec'd for handling, and that might reduce the life of tires anyway...I'm thinking of the Lotus Elise, that needs new rear tires every other oil change.
You could patronize a race shop for your alignment, that knows what changes result in desired goals.
Some characteristics (like when you said the 'wheel's camber is at maximum value') might require replacing parts to change...
Cass3958
28
May 1, 2021 05:04 PM
