F type AWD front Tyre inner wear
Old Jul 27, 2025 | 06:38 PM
George f type awd 3.0's Avatar
Default F type AWD front Tyre inner wear
Hi everyone.
The car : 3.0 awd 2019
problem - front wheel inner wear , factory pirelli p zero . 60.000 km
the guy who made wheel alignment today , told that everything is in green position, but wheels camber is at maximum value. Like - next time I will need to find problems in suspension.
somebody posted here , that the guy from JLR gave him a different wheel alignment numbers , anybody can help me with this problem. Thanks in advance.
Old Jul 27, 2025 | 07:19 PM
Carbuff2's Avatar
When we acquired our 2014, the inner edges of the front tires wore to the cords after 20,000 miles. We pointed this out to the alignment technician, who set the alignment to minimize this. (negative camber can aid ultimate handling). The alignment 'guy' followed our direction, and now the difference in tread depth inboard>outboard after another 20,000 miles is negligible. We do not track our F.
In fairness, I should mention that we replaced the original 200-treadwear P-Zeros with 500-rated UHP all weather 'shoes'. But as I said, I have monitored how they are wearing, with a tread-depth gauge at yearly oil changes.
Old Jul 28, 2025 | 05:05 AM
Oh thank you 🙏. But I need to understand clearly , is this thing normal , and I just need to change tyres on new ones , or it’s a suspension problem ? Cause I have tyres for winter, and I want to use summer tyres for summer use .
Old Jul 28, 2025 | 10:25 AM
Carbuff2's Avatar
Tyres/tires should be new for the most accurate alignment. If they are the same sizes, it should not matter if you have SUMMER or WINTER tires.
A GOOD alignment shop should be knowledgeable enough to set the adjustments within the specifications to achieve your goals. NOTE that some cars are spec'd for handling, and that might reduce the life of tires anyway...I'm thinking of the Lotus Elise, that needs new rear tires every other oil change.
You could patronize a race shop for your alignment, that knows what changes result in desired goals.
Some characteristics (like when you said the 'wheel's camber is at maximum value') might require replacing parts to change...
kevh
Sep 12, 2021 05:45 AM
Cass3958
28
May 1, 2021 05:04 PM
Pax
Jun 25, 2019 01:32 PM
CRS 123
Jan 4, 2019 12:13 PM
curscott
Jun 7, 2017 06:22 AM
