F-Type rear diffuser melted - exhaust too hot?
Old Oct 7, 2018 | 03:17 PM
saturdays's Avatar
Default F-Type rear diffuser melted - exhaust too hot?
Just noticed this today on my F-Type
Looks like the heat from the exhaust may have melted the area right above the tips, loosening the adhesive?
Any ideas on a good way to fix this? I'm in the Bay Area if that makes any difference
Old Oct 7, 2018 | 05:26 PM
Jst2gtby's Avatar
I would take it to the dealer. Have you done any modifications to the vehicle which you believe would cause this? Any recent rear bumper adjustments?
Old Oct 7, 2018 | 06:11 PM
saturdays's Avatar
Nope, the car is 100% stock. Think this would be covered under the new car warranty?
Old Oct 7, 2018 | 06:24 PM
Jst2gtby's Avatar
I can't see why it wouldn't be.
Old Oct 7, 2018 | 07:27 PM
Unhingd's Avatar
No adhesives in that area, only snap tabs. Valence or bumper could have been tapped by another car.
Old Oct 7, 2018 | 09:04 PM
saturdays's Avatar
Oh, I see. Hmm, there's no signs of any marks or scratches on the bumper, though if a car slowly pressed on it, that could have broken the snap tabs. We'll see what the dealer says
Old Oct 7, 2018 | 11:58 PM
SinF's Avatar
Abnormally hot exhaust could be a sign of oil burning.
Old Oct 8, 2018 | 08:20 AM
Unhingd's Avatar
I don't think the area around the pipes is sufficiently sooted to indicate burning oil (though, the area may have been recently cleaned).
Old Oct 8, 2018 | 12:29 PM
saturdays's Avatar
Yeah, the picture is right after I did a car wash. Typically, the area around the tailpipes has a bit of black soot on it. I assumed it's pretty normal, though, since it sounds like most other people see the same thing on this car.
Old Oct 8, 2018 | 06:59 PM
Unhingd's Avatar
I think so. When I still had the two trumpet exhaust tips, they were always sooting up quickly. I never noticed it much on the rear valence itself, as that is matte black.
Old Oct 10, 2018 | 02:04 PM
lizzardo's Avatar
That looks like two pieces, gloss black and body color, where there is only one on mine, all gloss black. I suspect physical damage, as has been suggested, or a possible workmanship defect.
Old Oct 10, 2018 | 03:25 PM
Unhingd's Avatar
I believe the valence is slightly different on newer vehicles. One piece on ours and two piece on the newer ones.
Old Oct 10, 2018 | 03:30 PM
fujicoupe's Avatar
Banned
Of course I had to look at mine and it's one piece matte black.
Old Oct 10, 2018 | 03:39 PM
Unhingd's Avatar
Saturdays, is yours an MY19?
Old Jun 13, 2020 | 08:01 AM
Cloudsurfer479's Avatar
Default Rearbumper melted by exhaust - here too
Hey all!
I know, it's already an old post, but it happened to me now, too....
I'm curious, what my Jag dealer will say on mondän. Car is completely stock, three months driven, now....
cheers,
thomas
Old Jun 13, 2020 | 10:57 AM
Unhingd's Avatar
Originally Posted by Cloudsurfer479
Hey all!
cheers,
thomas
The V6 tubes will get hot enough to melt the rear valence if the car is dyno’d (full throttle load) with insufficient airflow at the rear of the car.
Old Jun 13, 2020 | 12:25 PM
Hello!
Thanks for the info, but: it hasn't ever been dyne's, neither racetrack or similar things. Just normal roads and for the time being never flat out....
Furthermore, I'm living in Germany under not very hot climate conditions, so, I was really surprised when I saw this.
If this may happen under normal operating conditions, it's a construction issue...
But we'll see the local jag dealer's opinion into this next mondän...
Cheers!
Old Jun 13, 2020 | 12:27 PM
dyno'd and Monday ;-)
Old Jun 13, 2020 | 07:24 PM
Unhingd's Avatar
This is definitely not normal.
Old Jun 13, 2020 | 07:36 PM
OzXFR's Avatar
Yep, when I dynoed mine some three years ago now it was running over-hot (due to heat soak) with no extraction fan at the back that I can recall and it didn't melt or char anything.
Looking at those pics from Cloudsurfer479 I am seeing the opposite - instead of lots of black soot on the insides of the exhaust tips that you get when it is running rich I see very clean maybe light greyish deposits.
Tells me it has been running way too lean and therefore way too hot, and if it has been running way lean something (I know not what) must be causing it.
