F-Type SVR Hood Heat Shield info
Old Aug 6, 2020 | 11:01 AM
F-Type R 16's Avatar
Default F-Type SVR Hood Heat Shield info
Hello all,
I know a lot of people have been asking and looking for the small heat shield that clips under the hood and is recommended using once the engine cover is removed. Below are the part numbers and photo.
Heat shield: T2R23413
Clips-x4 needed: T2R16422
Total out the door was $150 USC
Looks great and well worth it in my opinion.
Old Aug 6, 2020 | 02:36 PM
madmax1911's Avatar
I didn’t know that was available, thanks
Old Aug 6, 2020 | 02:56 PM
Taylorguy74's Avatar
Are the hoods on the V8 S the same cutouts underneath for this to fit onto as your R? The only pic difference I have found is the actual vent openings themselves.
Old Aug 6, 2020 | 03:03 PM
I believe they are the same, worst case you return it but I’m pretty sure it’ll work.
Old Aug 6, 2020 | 03:23 PM
eeeeek's Avatar
Huge thanks. I didn't have any idea this existed, either.
Old Sep 12, 2020 | 09:30 PM
So, dealer wasn't much help here to confirmn fitment. Houston dealerships are the worst, but save for another time. I special ordered regardless and "restocking fee", yada yada - wrong fitment for V8S stamped hoods - I can assume it only fits R or SVR hoods with vents up front, not the spear vented hoods. Up for sale complete including shipping in Marketplace now. So disappointed, I was looking forward to a unique piece for my Jag.
Old Sep 13, 2020 | 04:10 AM
Unhingd's Avatar
Does the Project 7 come with an engine cover? If not, it may have a bonnet insert that would fit all the RWD cars.
Old Sep 24, 2020 | 03:03 PM
EJag66's Avatar
Taylorguy74,
Certainly interested if it is still available.
Never mind, just read the WFT
Old Sep 24, 2020 | 03:59 PM
Carbuff2's Avatar
Has anyone who removed the engine cover suffered any consequence without a heat shield?
We haven't, despite a couple 3 hour tours. (Cue the Gilligan's Island theme song. )
Old Sep 24, 2020 | 04:10 PM
Awd's Avatar
Awd
No issue for a ‘16 R at 4 track days
Old Sep 25, 2020 | 04:45 PM
Unhingd's Avatar
five years, 30k miles, no issues.
Old Sep 25, 2020 | 07:51 PM
madmax1911's Avatar
Thanks to Taylorguy74 I just installed the heat shield.
Probably belt and suspenders but hey, it can’t hurt and it’s a factory piece.
Old Mar 20, 2022 | 09:54 PM
gestut's Avatar
hi
So I have a 2020 type r. Assuming you have a type R as well
Old Mar 20, 2022 | 10:10 PM
gestut's Avatar
Originally Posted by F-Type R 16
Hello all,
hi where did you order it. I did a search on that part # and no luck.thanks
Old Mar 21, 2022 | 07:30 AM
Rondog's Avatar
So does the SVR have both the engine cover AND the heat shield attached to the hood???
Old Mar 21, 2022 | 07:35 AM
Carbuff2's Avatar
I thought, NOT.
Old Mar 21, 2022 | 09:30 AM
Therock88's Avatar
I thought, NOT.
Nope...Just the little tiny plastic thingy Does not have the large cover (I suppose someone could order one with it...But it is not stock with an engine cover).
Also running with no cover since I have had it...Running lots of HP too and a couple 1/2 Mile race days...No issues either. (Just another data point)
DC
Old Jun 17, 2022 | 09:18 PM
gestut's Avatar
Hello all,
hello
If I may ask where did you order it from I could not find anything on line, do i have to call the dealer?
thanks
Old Jun 18, 2022 | 09:34 AM
Whatsnext's Avatar
I guess I am a bit confused on the point of the shield. I removed my engine cover as well from the recommendations of others on this forum. I did read about how there is a potential issue with water getting in and saturating the deadening material for the supercharger. Is this for that reason? Because it appears from this shield it now blocking the air vents in the hood? Or is this to somehow prevent excess heat against the hood which could cause damage? I guess trying to fully understand its function. I live in AZ and other than when I wash my car, it doesn't get wet and clearly extremely dry here.
Old Jun 18, 2022 | 09:40 AM
gestut's Avatar
Originally Posted by Whatsnext
I guess I am a bit tossed on the point of the shield. I removed my engine cover as well from the recommendations of others on this forum. I did read about how there is a potential issue with water getting in and saturating the deadening material for the supercharger. Is this for that reason? Because it appears from this shield it now blocking the air vents in the hood? Or is this to somehow prevent excess heat against the hood which could cause damage? I guess trying to fully understand its function. I live in AZ and other than when I wash my car, it doesn't get wet and clearly extremely dry here.
hi
I was thinking the same thing. Haven't removed the cover yet. Waiting for the shield. I figure if svr was done this way you could not go wrong. I am not sure if svr has exact vent placement as R? P.s i am in Arizona too east valley . Where abouts are you?
