F-Type type-R h&r springs throwing adaptive dynamics fault code! Help!
Old Oct 31, 2018 | 09:26 PM
ftype_rocket's Avatar
Default F-Type type-R h&r springs throwing adaptive dynamics fault code! Help!
I lowered my f-type with h&r springs and its throwing adaptive dynamics fault code! What can i do to fix it?!?!?!
Old Nov 1, 2018 | 03:10 AM
Welcome to the forum ftype-rocket,
I've deleted your other identical post of this question from Jaguar Forums Feedback & Suggestion Centre and moved this one from General Tech Help to F-Type forum. This is the place to post technical questions about your model.
Old Nov 1, 2018 | 12:27 PM
FType17's Avatar
Check the ride height sensors as well as the electrical connector atop of the upper mount....
Old May 5, 2019 | 07:34 PM
Terrance39's Avatar
Did you ever figure out the cause of this?
Old Apr 2, 2021 | 09:39 AM
BJS470's Avatar
Bump.....having the same issue now. With VelocityAP springs. Was there a solution found?
Old Apr 2, 2021 | 10:11 AM
Terrance39's Avatar
You must've messed up one of the shocks during the install. I messed up my drivers side front shock and had to replace it, and the warning went away. The h&r's will not by itself cause the issue. Grab you a icarsoft scanner and it will tell you exactly which shock. Either that or you didn't plug back in the height sensor on the control arm, or you damaged that sensor as well. Regardless the scanner will tell you which one.
Old Apr 2, 2021 | 11:41 AM
BJS470's Avatar
turns out the leveling link was loose....thanks for the reply!
MichaelBrazier
Dec 21, 2025 04:39 PM
Bonz
Dec 31, 2019 08:21 AM
Jaggyx
Nov 6, 2019 02:51 PM
TAEUCK Goo
Aug 20, 2019 04:33 PM
DJP
Jul 9, 2018 07:02 PM
