F type V6S rear brake pads
Good Day Ladies and Gents,
recently, I stumbled upon an issue with my rear brake pads size.
I purchased ADJ134249/BLP Blue Print brake pads for my V6S with the length of about 104 mn and they do not fit! My mechanic has checked the current brake pads and they have around 114mm length. Why is that? Now, I can’t seem to purchase the correct pads, since every website suggests the same, 104mm pads when I type my F Type details.
May I ask for your advice in the matter?
attached, photo of my rear brakes. Do I have the optional super brakes 370+ mm rear?
kind regards
kind regards
Super Performance brakes were optional on the V6S, so if a brake pad listing doesn't show options for the V6S, I'd look up the R.
The 326 mm brake pads look identical to the 376 mm ones but they are not the same, as the OP has discovered the 376 mm pads are a smidge longer.
OK. Maybe I am.
In any case, if you've got the 379mm rear rotors, look for R pads.
Sonspit
Jul 11, 2014 08:52 AM
