Factory Model Year V8 CoolantPipe Upgrade
Old May 17, 2024 | 09:06 AM
Thunderjet Racing's Avatar
Default Factory Model Year V8 CoolantPipe Upgrade
Trying to separate fact from opinions and fiction on the model year where the V8 coolant pipe issue was finally resolved.
The final factory fix.
Thinking about moving from the P300 to an R model....... MAYBE
Anyone?
BEST !
RWS
Old May 17, 2024 | 09:32 AM
scm's Avatar
scm
I think the change was made partway through MY18 so any MY 19 or later should be okay.
Old May 17, 2024 | 09:55 AM
2000JagLvr's Avatar
@Thunderjet Racing Something to think about. While the coolant pipes were "upgraded" from 2 piece welded to solid one piece pipes, there have been reports of issues with them. Some say that the flange on the y pipe that fit into the engine block has failed on some cars. Some say it was not a failure of the pipe but was broken during the removal of said pipe. Either way, it is still plastic. The metal upgrade is not that difficult or expensive if you can DIY. I've recently done it and also the rear heater manifold pipe, thermostat housing and coolant pump. I sleep better knowing it's pretty leak proof now. And remove the D@mn symposer while your in there!
Good luck with the search.
Scott
Old May 17, 2024 | 11:41 AM
Originally Posted by 2000JagLvr
@Thunderjet Racing
<SNIP>
Scott
Symposer......... SYMPOSER ? ? ?
The V-8's have a SYMPOSER ?
This I cannot believe !
BEST !
RWS
Old May 17, 2024 | 12:08 PM
eeeeek's Avatar
You're not going to get a solid answer because it was changed mid-year.
Old May 17, 2024 | 06:43 PM
OzXFR's Avatar
BEST !
RWS
They stopped fitting the symposer to recent models, from MY 2021 IIRC.
So if you are looking to buy a newish P450 or R you don't have to worry about the stoopid symposer.
Dudong
General Tech Help
Sep 26, 2021 08:01 PM
RANGER1956
20
Aug 17, 2021 05:03 PM
Jimmy3Sticks
Jun 28, 2015 10:02 AM
Ftype-R
Jun 2, 2014 01:06 PM
Ronnieg
Mar 22, 2009 08:10 PM
