Fault Code P0599 / Thermostat Location
Old Sep 28, 2015 | 11:27 PM
zoozth's Avatar
Default Fault Code P0599 / Thermostat Location
Hi everyone,
I am getting a generic fault code P0599 for Thermostat fault, I think the way its detected is via load voltage, when the computer detects no load, it thinks the thermostat not working. I am getting no heating issue which if the thermostat really not working, it could be on the full open position when it stopped working.
I though i check the thermostat connector before I raise it with the local Jag dealer.
The engine is pretty covered up and I haven't been under the car yet, only got it 4 weeks now.
Could anyone post photos or schematics showing the location of the thermostat on a V6 F-Type?
Old Sep 29, 2015 | 06:10 AM
Foosh's Avatar
First, your generic code reader may not be telling you the real story. Since all F-Types should still be covered by warranty, you should take it to the dealer so they can check it with Jag-specific diagnostic equipment . Second, if you start taking things apart and damage something, you run the risk that problems you cause won't be covered under warranty.
Old Sep 29, 2015 | 06:47 AM
zoozth's Avatar
Agree
Definitely not planning to undo a single bolt. Was just wondering if the thermostat connector is accessible so i can make sure it's plugged well and save myself the trip to jaguar.
Old Sep 29, 2015 | 07:15 AM
Foosh's Avatar
Here's a V8 photo, but externally the V6 is almost identical (same block externally as well as associated parts). It looks like the thermostat is pretty well covered up.
Old Sep 29, 2015 | 07:17 AM
f-driver's Avatar
Hi
enclosed coolant system layout of V8 .
Number 25 shows housing of thermostat valve.
Because V6 and V8 are very similar I think you
will find it at the same location in your car .
Hth.
regards Ulrich
File Type: pdf
Old Sep 29, 2015 | 07:28 AM
zoozth's Avatar
Thank you very much guys. It doesn't look like ican reach the thermostat harness connector easily so reckon best make it a dealer problem.
Appreciate the response
cissdm
May 3, 2016 06:02 AM
skadmiri1
Sep 9, 2015 11:27 AM
OkieTim
Sep 8, 2015 04:48 PM
TexasCat
Sep 8, 2015 04:36 AM
