Front Differential
Old Jan 15, 2023 | 09:01 PM
F Type Terry's Avatar
Default Front Differential
Gentlemen,
Would it be ok to use BOT 720 on the front differential or go with the BOT 750B. I am not sure if there is a difference between. However, both has the same viscosity.
Old Jan 16, 2023 | 01:28 PM
Andi Jaguar G's Avatar
Originally Posted by F Type Terry
Gentlemen,
Hi,
I think the BOT 720 or BOT 750B s only for the back differential, not for front! I Have only this info (sorry not in english!)
I have an F-Type R AWD MY 2017!
DIFFERENZIAL-TYPEN ÖLSPEZIFIKATION TROCKENBEFÜLLUNG (LITER) NASSBEFÜLLUNG (LITER)
Fahrzeuge mit offenen Differenzialen BOT-750B 0,86 - 0,88 0,835 - 0,855
Fahrzeuge mit elektronischen Hinterachsdifferenzialen (ETM) BOT-720 1,26 - 1,28 1,22 - 1,24
Fahrzeuge mit Differenzialen mit begrenztem Schlupf (LSD) BOT-720 0,86 - 0,88 0,835 - 0,855
for the front differential is this the right one:
Castrol SAF-XO SYNTRAX LONG LIFE 75W-90
Füllmenge:
0,35 Liter ab leer
0,33 Liter Nachfüllmenge
Please check this information before you will do the service!
Andi
Old Jan 16, 2023 | 02:04 PM
scm's Avatar
scm
Would it be ok to use BOT 720 on the front differential or go with the BOT 750B. I am not sure if there is a difference between. However, both have the same viscosity.
Someone posted (not sure where, my notes didn't go that far!) that the rear e-diff requires Castrol BOT-720 and that if you put BOT-750B in an e-diff, it will be destroyed very quickly. So there must be a difference. I don't have info on the front diff.
Old Jan 16, 2023 | 02:12 PM
Yes, E Diff needs BOT 720 Not 750B!!!
But Not for Front, BOT 720 E Diff is for the back E differential
Old Jan 17, 2023 | 07:21 AM
skizot's Avatar
Do NOT use BOT 720 in the front. You need to use Castrol SAF-XO - 75W/90. (There are also alternatives to this as well. BMW - #07 51 2 293 972 is the same fluid.) You can also use Liqui Moly SAE 75W/90 / GL5 fluid (I prefer the LM stuff myself, but it is a personal preference.) Redline also makes a good fluid that would work too.
Old Apr 2, 2025 | 08:39 AM
Lothar52's Avatar
So what BOT oil is used for the front diff? Do they use a completely different oil or??
Hammer49
Mar 6, 2014 05:06 PM
Sledge
Mar 17, 2013 05:37 PM
jag79
25
Apr 1, 2011 05:25 AM
i h8 hites
Feb 1, 2009 07:18 PM
