Front Differential Fluid Change DIY
Old Mar 23, 2020 | 09:57 AM
Therock88's Avatar
Default Front Differential Fluid Change DIY
Hi Group...
As I mentioned in my previous thread on the Rear Differential DIY I took some photos and documented the Front Diff process, and put them in my DIY template. I have attached the Front Diff process here.
These are created in the spirit of helping others. If you have a better way of doing it, knock yourself out...this is simply what worked for me.
DC
Old Mar 23, 2020 | 12:02 PM
scm's Avatar
scm
Excellent write-up, thanks. BTW, your last comment about "if you have AWD" - er, you wouldn't be doing the front diff it you didn't have AWD!
Old Mar 23, 2020 | 12:05 PM
Therock88's Avatar
Thanks...And good point! I edited the document to reflect that minor issue.
DC
Old Mar 26, 2020 | 11:08 AM
SS4PK's Avatar
Do you plan to do the transmission too?
Old Mar 26, 2020 | 11:34 AM
Therock88's Avatar
Hi There....
Yes, likely at some point in the near future, and will similarly document and share. I ordered VAP Lowering Springs, but they are not in stock. When they come in (hopefully next week), I will be replacing the Coil Springs....So that will likely be my next DIY.
So far, I have done the following to the car in addition to the differential fluids: (All since November )
Racechip RS Install
Aluminum Pedals
Created LED Growler Front Badge
Installed Yellow Wolf Intake System
Installed Larger Paddle Shifters
Installed 15MM Spacers
Installed Rear Wing/Lip
Installed Rear Spoiler disable switch
Disabled Auto Star/Stop
Installed Front Wheel Arch extensions
Installed Battery Quick Disconnect for rebooting
Applied Ceramic Coating to the car
Had the front and sides wrapped with Xpel
And a few other minor mods I am probably forgetting
Will document when I get time...
Take care,
DC
Old Jan 17, 2021 | 08:39 AM
Ray Ray's Avatar
Edit: replied to wrong thread.
SecretSupercarOwner
Non-Jaguar Vehicles
Feb 29, 2020 06:45 PM
watson6505
Nov 28, 2019 12:03 PM
ANIMAL JAGUAR
Diesel variants - All models
Nov 14, 2019 03:06 AM
sweatyfox
Jan 19, 2017 01:10 PM
sweatyfox
Mar 8, 2013 05:13 AM
