Front sensors popping out? 10 Degrees out
Old Jan 14, 2024 | 06:40 PM
monacoftype16's Avatar
Default Front sensors popping out? 10 Degrees out
Hey folks,
Noticed the front sensors were popping out. Is this because of how cold it is outside? it’s currently 10 degrees. I’ve attached some pics, can anyone tell why? I did try to poke them back in.
Old Jan 14, 2024 | 06:48 PM
OzXFR's Avatar
They are not sensors they are the covers for the headlight washers.
My guess is that some water trapped behind them froze overnight and pushed them out, and then the ice melted away.
They should simply and gently push back in.
If that doesn't work you may need to operate them (turn them on) - set the ignition to ON, turn the headlights on, then hit the windscreen washer button a few times. The washer nozzles should pop out and spray the headlights on every third sweep of the wipers.
Once the washers have stopped check to see if the covers have now gone fully back into place.
Old Jan 14, 2024 | 07:19 PM
Carbuff2's Avatar
I wouldn't PUSH them in.
Just keep an eye on them...I bet they return to the fully flush position when the weather warms.
If they had a mechanical issue, it would be one side or the other sticking out.
Old Jan 14, 2024 | 10:20 PM
DJS's Avatar
DJS
Maybe you have summer washer fluid which froze.
Old Jan 15, 2024 | 03:27 AM
scm's Avatar
scm
One of mine was a bit misaligned so wouldn't return without a bit of help from me. Front fender realignment sorted that out (at the expense of slight misalignments elsewhere!).
Old Jan 16, 2024 | 09:02 AM
Therock88's Avatar
I would not push on them either. You will crack the plastic mechanism. As others said, wait until it warms...Or use a hair dryer and slightly warm it up. If it is frozen, it will melt and re-align. Also, may want to put some -20 degree windshield solution if you are driving or out during the winter.
P416
Jul 28, 2022 07:24 AM
Syb Drylst
Jun 6, 2020 12:42 AM
scottpeterd
Nov 13, 2019 06:46 PM
carelm
Mar 13, 2015 10:35 AM
ThomasX
Mar 11, 2011 02:37 AM
