fuel system treatment
Old May 19, 2021 | 05:37 AM
2004XJ8's Avatar
Default fuel system treatment
Hi guys,
Quick question I just did a BG44 Fuel system treatment prior to my oil change. 1 full tank. Is this sufficient enough for the 3500 miles a year I drive to keep injectors clean and carbon at bay?
or should I use something every 2 or 3 fill up's? Maybe another product suggestion that is also good. I will continue to use the BG44 before each oil change, at least once a year.
Thanks for your help!
Old May 19, 2021 | 06:20 AM
Therock88's Avatar
Just an opinion, as I am sure others will have similar or different opinions. I think what you did with the BG44 is great. Given that you drive so little each year, it is likely that you have "old" gas sitting in your car quite a bit. If this was my situation, I would also (and I actually do this on mine), run a few ounces of Lucas Fuel Treatment through my tank every couple of fills also. Besides cleaning the injectors, it also stabilizes the fuel. It is cheap insurance. I get the quart size bottles and just put 4-6 ounces in every other tank.
DC
worzella
Apr 29, 2021 10:48 PM
Dukejag
Mar 23, 2020 02:28 AM
croco
Sep 9, 2017 01:39 PM
Mike Beda
May 13, 2017 01:31 PM
Shoreguy
Jan 27, 2017 08:14 PM
