Fuel Tank vs Gauge
Old Oct 30, 2023 | 07:47 PM
MellieR's Avatar
Default Fuel Tank vs Gauge
Noticed the last two times I got gas (fill up) that the tank was not showing full as I pulled away. First time didn’t give it much notice. Second time I wondered if there wasn’t something off with the pump as both fill ups were at the same station and the same pump. Now I’m paying attention.
In my previous FType, I had the issue where the pump would cut off after just a few gallons and you would have to rotate the nozzle to get it to accept. Was a problem with the fuel filler neck I believe and somewhere floating around is a TSB for it. From that, I got pretty good at estimating how many gallons I would need at each fill up before I got it fixed. Current FType does not have this same issue.
For this last fill up I was at a different station, in a different town. Expected to need approx 13 gallons based on gauge level. Pump clicked off at just over 10. Nudged the car a bit and fed in a little fuel to see if it would take more. Fuel was visible in the filler neck and level was not going down as I bumped the car again. Fuel that ran out when bumped drained down the overflow tube (there was minimal amount). Led me to believe it was truly full. I told myself I hadn’t yet had coffee and must have just looked at the gauge wrong. Nope. Start up and I have a gauge showing over 3/4 tank but not even close to full.
Did a search here and can’t seem to find similar reports for other FTypes. There was an instance reported in an older (2012) XF but that was also a single report. A few more in the XJS threads. All reported Fuel Sender Sensor.
My first thought was a breather tube came loose (?) but I only have rudimentary knowledge of fuel systems, so it’s a guess.
This is on 2017 V6S, just over 51k on the odometer. Approx. 10k of those miles are mine. I don’t run the tank empty (it just goes against everything in my soul), top tier fuel only. No CEL.
She’s under warranty and going to dealer on Friday after I take a few days to run the tank down (darn the luck!). But mostly curious if anyone else has experienced anything similar?
Old Oct 30, 2023 | 08:49 PM
DJS's Avatar
DJS
My fuel gauge would never get below ‘48 miles to empty’, just above the red mark. Even showed that when I ran out of gas on I-90 in MN. It now rarely goes below 1/2, I use the trip odometer. Haven’t gotten around to having it fixed, but it was pretty clearly defective from the factory.
Old Oct 30, 2023 | 09:46 PM
MellieR's Avatar
Did you post about that here? Seems I remember someone had an adventure trying to get fuel a few years back. That may not have been you though.
Regardless, thanks for the comment. I’ll update once I have more info from shop.
Old Oct 31, 2023 | 05:46 AM
DJS's Avatar
DJS
https://www.jaguarforums.com/forum/f...-empty-235265/
The fuel gauge worked OK for 7 years or so, though never getting below about an 1/8th of a tank. When I took it out of winter storage a couple of years ago, the gauge didn’t move at all for the first tank. After that, it only goes down to about 1/2.
The dealer indicated there’s an access port somewhere for accessing the tank, so replacing the sender isn’t a huge job. They suggested replacing the pump while there. As they pissed me off on another job (they’ve always been good if expensive), I didn’t follow up.
Old Oct 31, 2023 | 08:23 AM
Dwight Frye's Avatar
You might try running some Marvel Mystery Oil (in the recommended dosage for fuel) through the gas tank a couple of times. I used to own a Nissan 370Z and wonky fuel gauges were a known issue. I ran nothing but top tier fuel through it but a few times a year the gauge would fail to read full. MMO cured it for several tanks and it would reoccur again. The MMO acts as a solvent and your car's fuel level sensor or float may be a bit sticky. It's certainly worth about $7-$8 to try.
Old Oct 31, 2023 | 12:51 PM
clubairth1's Avatar
Community Influencer
I have had gas gauge problems on a different car and the suggestion was to try an additive that had a high PEA content?
Here is a thread discussing it. I tried one of those high PEA products and noticed no change but it was a suggestion?
PEA Additive for Fuel Gauge?
Old Oct 31, 2023 | 01:37 PM
DJS's Avatar
DJS
Thanks, I do an annual BG44K treatment.
Old Oct 31, 2023 | 06:11 PM
clubairth1's Avatar
Funny I do to!
cstall
May 17, 2021 03:52 PM
carealtor
May 15, 2021 03:55 AM
SJones
Oct 31, 2019 12:20 AM
Lcgi
Sep 6, 2012 07:27 AM
amcdonal86
Jan 19, 2012 10:00 PM
