Gas cap leak
Old Mar 6, 2026 | 03:45 PM
Ernie1234's Avatar
Default Gas cap leak
My 2017 f type s had a gas cap issue - leak causing check engine and restricted performance….. cap replaced by jaguar . Now 2 months later I’m having the same issue with check engine due to leak. What could be going on? Could the actual tank where cap screws into have an issue? Thanks
Old Mar 6, 2026 | 03:52 PM
RRpip's Avatar
Yeah, totally get it. So if a brand new cap didn't fix it, the problem is likely somewhere else in that system. The most common thing on these cars is the actual plastic filler pipe where you screw the cap on it can crack or warp. Also, sometimes a small hose underneath gets knocked loose or dry rotted. Might be worth having them check those spots instead of just throwing another cap on it.
Old Mar 6, 2026 | 04:03 PM
Carbuff2's Avatar
First, get a DTC code. Could be a different component of the Evaporative system.
Verify that there is no damage to the filler neck where it contacts the gas cap's gasket.
A little ding can cause the issue.
A light coating of petroleum-resistant grease ("brake grease') on the gasket of the cap will help reduce issues.
Old Mar 6, 2026 | 04:05 PM
Ernie1234's Avatar
Thanks!
Old Mar 6, 2026 | 07:38 PM
Valerie Stabenow's Avatar
The original cap on my 2017 took 2-3 clicks to lock completely. The new cap I have doesn't do that, but you do have to press in and rotate as much as you can. A failure to close it completely will create that CEL. Have the same issue on my 2013 Golf.
hornet9988
Nov 23, 2022 10:04 AM
Charbinjr
Jun 27, 2017 07:00 PM
Oldman
Aug 3, 2013 10:48 AM
MRomanik
Sep 9, 2012 06:10 PM
majbill
Apr 20, 2010 07:43 PM
