Group Buy: VS Forged Wheels
Old Dec 23, 2018 | 01:06 PM
  #61
F-Type-Type's Avatar
Originally Posted by jaguny
@F=Type Type: What is the finish on the Stance VSO2's? They look great with the white body color.
Thanks. The finish is "Brush Titanium". Originally I wanted to go for a black finish, but then decided that I would like to be able to see the milling markings from the wheels being machined from a solid block of forged alumium. I am very glad I changed, the Brush Titanium looks terrific. The only negative aspect that I can mention about ordering the Stance Forged wheels was the delevery delay. I ordered start of June 2017 and received them mid September 2017. A two months delay seemed like forever, but was all worth it in the end. However, the VS2 is very open and showed the boring EOM rotors so I had to finished the job with the great looking Wortec (group buy) rotors this summer, cf. photos.
Old Dec 29, 2018 | 12:05 PM
  #62
Unhingd's Avatar
Default Wheels arrived
Front: 21.8 lbs , Rear: 24.4 lbs. 10 lb weight savings per corner. These are the VS03s in brushed titanium/diamond cut.
Old Dec 29, 2018 | 12:46 PM
  #63
jaguny's Avatar
They look great. When will you install?
Old Dec 29, 2018 | 02:51 PM
  #64
Unhingd's Avatar
Tires arriving on Wednesday, so probably on Thursday next week. Too much cord showing on the front PSSs, but was holding out for the new wheels to arrive before I mounted a new set of PS4Ss.
I figured out how to fabricate growler center caps.
Old Dec 29, 2018 | 05:02 PM
  #65
scm's Avatar
scm
C'mon, man, growler chin to valve hole!
Looks good, anyhow.
Old Dec 29, 2018 | 05:05 PM
  #66
These forged wheels are works of art. The lightweight is due to the precisely machined extremely thin walls. These thin walls of the rim challenged my tire guy since the thread of the valve stem ended well before the valve “nut” abutted with my VS02 rim, so he had to obtain a special vavle nut to get the vavles secured. Was all worth it, light and great looking! I also have the PS4S on them, fantastic tire, better grip and much better rolling comfort than the stone walled Pirellis. Congrats with the VS03’s!
Old Jan 2, 2019 | 06:53 PM
  #67
Tork Monster's Avatar
Received one of the four today. Looks great and, although I haven't weighed them, feel very light.
Scheduled for install Monday. Can't wait.
yeah.. the car is quite dirty.
Old Jan 2, 2019 | 07:04 PM
  #68
Unhingd's Avatar
It will be interesting to see how much the 21” wheels weigh versus the 20”.
Old Jan 2, 2019 | 07:27 PM
  #69
The 10.5" rears weigh 27.7 pounds, a few more than your 20" rears, but less than the stock wheels.
Going up in wheel diameter is never a means to lower unsprung weight... and although transient response is improved, most all other aspects are worse. Tire costs, availability, ride, traction, road noise... but I love the look of the larger rims, and upgrading to Michelins will hopefully offset the performance drawbacks.
Now, how can I persuade you to build me a set of Growler center caps?
Old Jan 2, 2019 | 07:44 PM
  #70
jaguny's Avatar
Tork Monster: what finish are yours?
Old Jan 2, 2019 | 08:38 PM
  #71
York Monater: what finish are yours?
HyperSilver. I wanted them to be as close to the stock rims as possible.
-York
Old Jan 3, 2019 | 04:41 AM
  #72
jaguny's Avatar
Red face
-York
York, That was a real hack job on the auto spell check. Corrected.
Old Jan 3, 2019 | 09:32 AM
  #73
LOL- no offence taken Typos and auto correct are a way of life now-a-days
Hoppy New Bear!
Old Jan 3, 2019 | 10:22 AM
  #74
eeeeek's Avatar
Do tell. What did you do? I've seen growler center cap 'stickers' on ebay. I'm looking for a clean solution for myself.
Old Jan 3, 2019 | 11:27 AM
  #75
Although I like the VS-Forged center caps, the Growler caps match the red calipers on my car, and I feel they will look better.
The VS-Forged wheel center caps are larger than the stock centers... ~67mm as compared to ~57mm, so the pop-in caps available don't fit. I just bought some centers that adhere to the flat surface of the VS-Forged caps. They are contoured, match Jags's logo, and are quite inexpensive too. The adhesive on the back works well, as long as the surface is clean.
VS-Forged Cap:
Here is a link from Amazon (there are many available):
https://www.amazon.com/JXHDKJ-W005-R-Styling-Accessories-Sticker/dp/B07DCBJ8HX/ref=sr_1_22?ie=UTF8&qid=1546533141&sr=8-22&keywords=jaguar+badge https://www.amazon.com/JXHDKJ-W005-R-Styling-Accessories-Sticker/dp/B07DCBJ8HX/ref=sr_1_22?ie=UTF8&qid=1546533141&sr=8-22&keywords=jaguar+badge
or this:
https://www.amazon.com/FidgetGear-Wheel-Center-Emblem-Jaguar/dp/B07H79BP1G/ref=sr_1_137?ie=UTF8&qid=1546533691&sr=8-137&keywords=jaguar+badge https://www.amazon.com/FidgetGear-Wheel-Center-Emblem-Jaguar/dp/B07H79BP1G/ref=sr_1_137?ie=UTF8&qid=1546533691&sr=8-137&keywords=jaguar+badge
Old Jan 3, 2019 | 02:12 PM
  #76
eeeeek's Avatar
VS-Forged Cap:
Here is a link from Amazon (there are many available): https://www.amazon.com/JXHDKJ-W005-R...s=jaguar+badge
or this: https://www.amazon.com/FidgetGear-Wh...s=jaguar+badge
I'm cursed with a background in graphic design. That one looks different enough that it would bug me. Thanks for the link, I'm going to find one that's spot on.
Old Jan 3, 2019 | 02:30 PM
  #77
I'm pretty OCD myself. If you find one please post a link. At $12 I have no problem replacing them with ones that are more accurate.
Old Jan 3, 2019 | 03:29 PM
  #78
eeeeek's Avatar
My center caps are about 70mm, so I can use a grill sized one.
Old Jan 3, 2019 | 06:54 PM
  #79
Unhingd's Avatar
Tork Monster,
You did exactly what did. The sticker coincidentally fits perfectly into a raised ring on the VS center cap to ensure that it is perfectly centered. I too am a bit bothered by the graphic variance from the OEM center cap, but not having a Red Jag center cap would drive me batty. I think the scale of the nose ornament is just too far out of proportion to look right.
edit: physically won’t work either. The grille emblem would partially cover the lug holes.
Old Jan 3, 2019 | 08:38 PM
  #80
BruceTheQuail's Avatar
I have the same issue with my Vorsteiner caps. I thought about doing what you have there (or getting blank caps and putting a Jag stick on) then I thought of getting Vorsteiner caps in red (about $200 from memory, wtf!?) and then after a few weeks I moved on to some other obsession and forgot all about it until I read these posts, now I am a bit "meh" about it all as I'm more focused on partially debadging and replacing chrome badges with black.
