Group Buy: VS Forged Wheels
Old May 29, 2019 | 06:27 PM
  #161
Bray's Avatar
Originally Posted by jaguny
Lance, I would hope these guys could get it right, having done shop drawings (hopefully overlaid onto a section cut of the wheel setup). They did do the other f type I and Tork posted photo of, but that had CCB brake package. They are guaranteed fit, so if they are wrong, I will need to get a new set of fronts. Jut looking at the photos and comparing to the BRG CCB f type, it appears my rears are more concave, although that just may be an illusion.
How did you know which offset to choose? My specs currently for my f type are
295/30zr20 101w in the back
255/35zr20 97w in the front for tires
Rims 9x20 in front 5x108 bolt pattern
Rims 10.5x20 in back 5x108 bolt pattern
Old May 29, 2019 | 06:54 PM
  #162
Unhingd's Avatar
101 and 97 are tire load specs, not offsets. The OEM offset is 55mm in front and 38mm in back. You can safely reduce each of those by 15mm to get the wheel more flush with the fenders. Some of us went with wheels that were 1/2” wider than stock. That requires a recalculation of the offsets.
Old May 29, 2019 | 07:04 PM
  #163
Bray's Avatar
Thank you very much for your response! I appreciate you helping me out!
Old May 29, 2019 | 07:36 PM
  #164
Bray's Avatar
Just got off the phone with Paul and purchased the VS07 set in brushed bronze. He said a 35mm and 24mm offset. Is that okay or too much?
Old May 29, 2019 | 07:48 PM
  #165
Unhingd's Avatar
If those are offsets for 9” and 10.5” wheels respectively, that will work (and look good).
Old May 29, 2019 | 09:01 PM
  #166
Tork Monster's Avatar
Mine are +32mm front; +25mm rear. I have no issues, no rubbing at all (21" diameter), but I would not go with much less offset than that.
1mm less offset in the rear would barely be measurable (1mm<1/32"), and the front is about 1/8" further out than mine. You can see the fitment in the photo below. You should be okay if your wheels are the same widths (9" front, 10.5" rear)
Old May 29, 2019 | 09:06 PM
  #167
Bray's Avatar
Do you recommend getting the wortec rotors as well?
Old May 29, 2019 | 09:18 PM
  #168
Bray's Avatar
[QUOTE=Tork Monster;2077771]Mine are +32mm front; +25mm rear. I have no issues, no rubbing at all (21" diameter), but I would not go with much greater offset than that.
Thank you for the info! You're car looks great! I like the lowered look too, it definitely makes a difference in the look, you said you installed AP-Velocity progressive rate springs? Does it also make a difference while driving?
Old May 29, 2019 | 09:48 PM
  #169
jaguny's Avatar
Here is the wortec group buy thread. I didn't buy them but would consider it in the future when funding allows. Others can chime in on how they like them. They are expensive, but for the right reasons.
https://www.jaguarforums.com/forum/f...f-type-197525/
Old May 29, 2019 | 10:01 PM
  #170
DJS's Avatar
DJS
Make sure you have the Super Performance Brakes if looking at the Wortecs.
  #171
Bray's Avatar
Thank you once again! Dang it I missed all the group buys lol still am thankful for all the knowledge and help you have all provided
Old May 29, 2019 | 10:05 PM
  #172
Bray's Avatar
I just purchased the AP-Velocity progressive rate springs as well
Old Jul 8, 2019 | 03:28 PM
  #173
Jaggyx's Avatar
Thanks to everyone's help with the offset information in this thread. I just pulled the trigger on some BC Forged EH181's. Although the finish below could have looked great on a black car, I went a bit more conservatively and opted for a brushed clear finish.
20x9.5 ET41
20x11 ET29
Old Jul 9, 2019 | 08:30 AM
  #174
AaronLin's Avatar
Default Brushed Clear is superb....
20x9.5 ET41
20x11 ET29
BC Forged has the thickest clear-coat
Old Jul 9, 2019 | 05:40 PM
  #175
jaguny's Avatar
Jaggyx, great choice. I see you went with monoblocks. Will be lighter than two piece. Post photos when on.
Old Jul 10, 2019 | 12:43 AM
  #176
Jaggyx's Avatar
Yes, the BC Forged brushed finishes look really good.
Thanks -- cannot wait!
Old Jul 12, 2019 | 03:23 PM
  #177
Jaggyx's Avatar
Those with aftermarket wheels, did you guys have to purchase any specific valve stems to accommodate the TPMS sensors?
Old Jul 12, 2019 | 03:47 PM
  #178
jaguny's Avatar
I think the installer provided new TMPS sensors. I may have the box in the trunk of the car the sensor came in. I can check on Monday. Car still at the office.
Old Jul 12, 2019 | 10:49 PM
  #179
Unhingd's Avatar
Valve stems are an integral part of the TPMS sensors. Any TPMS sensor will fit the wheel. The critical issue is to ensure that the sensor is compatible with the F-Type TPMS. That will differ depending on model year.
Old Jul 13, 2019 | 06:00 PM
  #180
Jaggyx's Avatar
I'll be using the same TPMS sensors now, so non issue in terms of figuring out which frequency I require. I'm sure the installer will have TPMS valve stems so I'll go from there.
