Hard Wired Battery Tender- Front bumper
Old Jan 7, 2015 | 07:12 PM
WaltB's Avatar
Default Hard Wired Battery Tender- Front bumper
I like to have easy access direct plug in battery Tender charging when I am not driving my vehicles. So today, I spent a little time and created a direct connection under the front bumper.
The positive wire was bolted to the small jumping panel under the front hood with the negative connected to the frame using a pre-existing bolt that had other wires doing the same. Then a small notch was cut on the Red cover to allow the wire to exit without being pinched. (The smaller cover will not fit over the panel so I removed it completely.)
I now have an external, easy accessible, Battery Tender hook up for when the Jag is in hibernation. Previously I had been using the rear hood battery access until I put her on the lift.
Simple to do and very easy access so those intimated by these types of projects don't be.
Walt
Old Jan 7, 2015 | 07:46 PM
Foosh's Avatar
It's certainly very creative, Walt, but I'd rather open the trunk to plug it in rather than get on my knees looking for the plug-in under the front nose. The pigtail is also protected in the trunk against road dirt, grime, and debris. The trunk lid closes easily over the small BT cable, and I have the pigtail routed to a point just under the trunk latch.
If you're doing most of your storing on a lift, I certainly see why it's more convenient for you.
Old Jan 13, 2015 | 10:36 PM
FR_racer's Avatar
WaltB, I like the look of your car cover. Could you please share some details with us (mfg., model, etc.)? Thanks!
Old Jan 14, 2015 | 03:18 AM
WaltB's Avatar
Sure, here you go.
Covercraft Form Fit Car Cover - Best Price on Form Fit Indoor Car Covers
Walt
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
bdboyle
Sep 4, 2015 06:16 AM
OkieTim
Sep 2, 2015 12:48 PM
