Hello from a new owner and member
Old Feb 16, 2021 | 12:09 PM
RickyJay52's Avatar
Originally Posted by bertnd
good to know about Scarborough Jag- i'm only 20 mins from there. Maybe see you there this spring!
I’m not waiting for spring Anthony—life’s too short—as I venture over to Jaguar Land Rover Scarborough often enough. Even during winter. In Maine. I wouldn’t even consider taking my car, or me, anywhere else!
Congratulations on your car.
Old Feb 16, 2021 | 12:16 PM
bertnd's Avatar
I like your style! Once i get the P-zero's off and throw on some pilot sport A/S3's, I'll drive much later into the season.
Old Feb 16, 2021 | 12:24 PM
RickyJay52's Avatar
Just an FYI: I have Continental ExtremeContact DWS 06’s on...well...all my cars and love them so much I never take them off. Continental Tire actually has an updated version of that tire which I don’t know anything about.
Full disclosure: I am NOT—much as I like the idea—a paid spokesperson for Continental Tire. Merely an extremely satisfied customer. That and they have sponsored 4 of the 6 events I’ve hosted in the Great State of Maine since spring 2016. They produce a shirt which I design and have given out to both attendees and many of the people we meet and places we go (including a few Jaguar F-Type Forum members here).
If you happen to wear a Medium—the one size I still have left—a 2020 Jaguar F-Type Ghost Tour (the last event I hosted in Oct 20202, and last event of it’s kind) it’s yours.
Old Feb 16, 2021 | 12:40 PM
bertnd's Avatar
Thank you, but alas, at 6'2" and 200lb, i haven't worn a medium since i was 14. I will definitely look forward to supporting you and your events in the future by purchasing a large
Old Feb 16, 2021 | 12:48 PM
RickyJay52's Avatar
I—many here—get it.
Unfortunately—and I realize that this is a bit of an inside joke—I don’t think there will be any more events. [But...you never know]. The last 4 (I’ve hosted 6) were by invitation only—for numerous reasons—and the shirts—sponsored by Continental Tire (with their LOGO as well as that of Bangor Savings Bank; who has also sponsored our events)—come totally free. In other words, “no purchase necessary”.
Old Feb 16, 2021 | 01:05 PM
SinF's Avatar
Welcome to F-type ownership, you are now a proud owner of a Jaaaaag minus Lucas and oil leaks. As F-type shares a lot of mechanics with earlier Jaguar XKR, even early F-types benefit from 'mid cycle' mechanical updates and are considered reliable. As no car is perfect, there are few common themes and re-occurring flaws that you will have to deal with.
Issue 1: Cooling system and plastic coolant piping - unfortunately a number of plastic coolant pipes in the engine bay were made from material that becomes brittle with age and splits at the seam. This was made worse by adding an insulated engine cover that traps heat in the engine bay. Some of these coolant pipes are in the engine valley, requiring removal of supercharger to replace. Parts were updated around 2017 to seam-less design to prevent splitting, but your F-type does not have them installed from the factory. These can fail two ways - sudden failure where you dump all coolant and overheat the engine or slow leak. Sudden coolant loss is more dangerous as in-dash engine temperature indicator displays a running average and not instant engine temperature measures, delaying when the driver notified about overheating. So by the time you see the dash warning about overheating the engine have been cooking, potentially without any coolant at all, for a few minutes. Treat anything related to cooling system as an emergency, do not wait to pull over, shut the engine off, and open the hood. If you get coolant warning, have the car towed unless you can confirm it still has coolant. While this might be an overkill, I also ask my garage to pressure test cooling system every year prior to storing it for the winter. Additionally I permanently removed engine cover and it had measurable effect on reducing engine bay temperature.
Issue 2: Engine oil and sludge. AJ133 V8 and AJ126 V6 engines in F-type use direct injection (DI). DI means these engines are prone to developing sludge on intake valves if oil is neglected. These engines also use oil pressure to control variable timing. All of this means that things go bad very quickly when the oil gets dirty. Fortunately, frequent oil changes using spec oil shown to largely mitigate sludge. It is very crucial that you stay on top of oil changes and use spec synthetic oil with specified additives. Also keep in mind AJ133 V8 doesn't have low oil pressure sensor (yes, you read it right), this means you can run the car dry and it will not warn you. All of this means that you have to be religious about changing oil and monitoring engine oil level.
Issue 3: Injectors. AJ133 V8 and AJ126 V6 engines in F-type use direct injection (DI). This system has two stage fuel pumps and high-pressure injectors. This setup means that running out of gas has a chance to damage pumps, so take care not to do that. Injector failures are unfortunately known to happen where the whole rail has to be replaced, but can be mitigated with regular use of PEA-containing injector cleaning. I recommend running PEA fuel additives like BG 44K annually or budget for injector replacement in a couple years.
Issue 4: Battery and charging. When you plug anything into OBD port, power management control module is known to get glitched and not completely power the car down. This in turn runs the main battery flat as the car never fully shuts down. To fix this, you need to disconnect the main battery to reset the power control module. Dead battery in a locked car is a huge inconvenience, as you need power to open the trunk to access the battery, so it can lock you out of the car and it is nuisance to get it resolved. My suggestions: a) know emergency unlock procedure (with mechanical key hidden in the fob) and boost points in your engine bay b) avoid using OBD readers or assume it will glitch and reset PCM after each use. You can visually tell that the car did not fully power down if emergency triangle stays illuminated 10 minutes after you locked the car - this means PCM is glitched. More so, having marginal battery on these cars is known to trigger all kind of fault codes, so if you suddenly see multiple dash warnings about unrelated things... don't panic, it just might be a marginal battery.
While this is not a fault or mechanical issue, make sure to stay on top of transmission, differential, supercharger oil, brake fluids and engine coolant changes. Low miles on your car does not mean that original fluids are fine - as they degrade both with use and time. Unless you have records from PO, assume that nothing other than oil changes was done (many people treat lease cars as a rental). This means you have to catch up on all other fluid and filter changes. Changing engine oil is critically important, but there are other fluids and filters that also have to be regularly changed. Especially important is transmission fluid and filter - these cars come equipped with a superb automatic transmission that I expect to last forever, that is unless you never change transmission fluid. Based on the year of your car, you are overdue on coolant and brake fluid changes and due on transmission fluid change.
Old Feb 16, 2021 | 01:43 PM
bertnd's Avatar
thanks- previous owner was pretty meticulous with service, but i always like to baseline fluids when i get a new to me car- they're all on the docket for spring for sure. And even though they are "more" reliable than previous, I would NEVER purchase a JLR without a full warranty. Fingers crossed i have many miles of trouble-free fun ahead.
Old Feb 16, 2021 | 06:27 PM
  #28
Mbourne's Avatar
Since your rear badging appears to be correct it looks like the previous owner added the extra side badges. As long as your engine spec is the S version your good to go. You can run your vin number through the https://www.jaguarforums.com/forum/vindecoder.php to make sure you truly have an S.
Great purchase and enjoy!
Old Feb 16, 2021 | 06:33 PM
OzXFR's Avatar
Easiest way to check is to pop the hood and look at the tops of the front strut mounts. If they have wires and an electrical plug on them then you have active suspension = S, if not = Base.
Old Feb 16, 2021 | 06:35 PM
  #30
Mbourne's Avatar
+1. Thanks Oz,I forgot about that one.
Old Feb 16, 2021 | 07:20 PM
  #31
Sparky H's Avatar
Welcome Sir......Sweet F Type...Terrific Forum
Old Feb 16, 2021 | 08:17 PM
  #32
BritCars's Avatar
Great that we have two new members buying sports cars in Maine in the middle of the winter! Welcome to you both!
Happy motoring! Car looks terrific
Old Feb 18, 2021 | 09:36 AM
  #33
Mary BAM's Avatar
Beautiful car & color! Not only because its my color as well! I chose a traditional interior AND STANDARD transmission. Just moved the car to MT where there are now probably 3 of us with convertibles - 2 of us lovely blonde ladies - go figure! Have fun with your car, take many road trips because it doesn’t matter the distance (I drove it out from CT) - as soon as you get out of the car, you will want to get back in it & head out again. I took 7 days to drive it out - heading north through Canada (pre-Covid), then back into the US, through the upper peninsula of MI, then dropping into ND & a few stops in my home state of MT before getting it to Northwest MT. Can’t wait to get her back on the road again!
Old Feb 18, 2021 | 10:18 AM
  #34
RickyJay52's Avatar
Nice photo, car, and wave. However, when in an F-Type—any F-Type—this is the preferred manner in which to wave:
Old Feb 18, 2021 | 10:26 AM
  #35
frank barone's Avatar
Beautiful woman beautiful jag. Can’t beat that combo. What a great adventure you had driving to MT. Maybe a short account of what you experienced during your trip, I’m guessing that their are a number of us on this forum would love to know. You’re are certainly one who doesn’t have to told “drive your jag that’s what they were made for”, you do!
Frank
Old Feb 19, 2021 | 10:05 AM
  #36
Burn123's Avatar
Hello,
Great info you provided on the very important maintenance items to stay on top of. Question: you mentioned supercharger oil change...I assumed this occurred while doing the engine oil R and R, is there a separate oil drain and fill for the supercharger?
Thank You
Old Feb 20, 2021 | 06:24 AM
  #37
Therock88's Avatar
Originally Posted by Burn123
Hello,
Thank You
Yes... SC oil is separate and a different type. I did a DIY HERE.
DC
Old Feb 20, 2021 | 12:07 PM
  #38
HermanWiegman's Avatar
Great to see the cars out an about... I am able to put a few miles on my 2017 every few weeks.
Welcome to the forum, and also pay attention to SinF's post from a few days back.
1. remove engine cover to keep the plastic bits healthy
2. change the oil and check level
3. keep you injectors clean (I installed two catch cans and will report back on that later)
4. reset your car after interfacing OBD dongles.. (Ok, I was a bit slow on the uptake, and recently drained my battery ... twice.)
Here is my BRG Coupe with 6-sp MT out for a spin in the snow in Vermont.
Vermont Cat Jan 2021
Old Feb 25, 2021 | 10:59 AM
  #39
Burn123's Avatar
Thanks DC...Great intel as usual!!!
sgvkirbster
Feb 15, 2021 09:01 PM
Mueller
Oct 12, 2016 06:45 PM
jagftype
Sep 15, 2015 01:11 PM
Masher02
Feb 23, 2015 02:14 PM
duprey26
Dec 27, 2014 07:13 AM
