Help asap!!
Old May 23, 2022 | 09:57 PM
bjg625's Avatar
Default Help asap!!
Is there a special tool to release trans from inside center box? Getting towed tomorrow just in case. Thanks
Old May 23, 2022 | 11:19 PM
bjg625's Avatar
Answered own question by looking myself, pull!
Old May 23, 2022 | 11:21 PM
OzXFR's Avatar
Easy schmeasy, it's in your Owner Manual (page 195 in mine) under Vehicle Recovery, copy attached.
Under the centre console lid/hatch is a rectangular plastic cover, on the the left side or right side of the box (mine is on the left side but mine is RHD so maybe on a LHD car it is on the other side, I dunno).
Lever this cover off with a small stubby flat blade screwdriver, there is a small slot on the underside of the plastic cover just a mm or so back from the front edge.
Then once the cover is off you will see a red/orange strap and a slot inside a circular piece at the front end of that strap. Grab your screwdriver and turn that slot 90 degrees and the mechanism underneath releases and springs up a little.
Then grab the red strap and pull it straight up, this releases the Park pawl and puts the trans in Neutral.
The "special tool" is a stubby screwdriver which I carry all the time in the centre cubby!
File Type: pdf
Old May 24, 2022 | 01:13 AM
bjg625's Avatar
Old May 31, 2022 | 11:40 PM
bjg625's Avatar
lost 2 fuel injectors on one side, at minimum needs one bank of injectors and 6 plugs, inde shop seems very expensive as parts come to about $450 online, even if they charge double they want $2k in labor. I'm going to get a price from dealer and try to negotiate them down.
Old Jun 1, 2022 | 01:00 AM
OzXFR's Avatar
Don't be too surprised at the high quote as the fuel injectors can be a real bear to remove on these engines as quite often they are stuck super tight and it can take hours to get them out.
Stude51
Non-Jaguar Vehicles
Jul 13, 2021 05:15 AM
Dancer
Dec 13, 2020 02:08 PM
XJ ate
Oct 4, 2009 02:22 PM
