Help installing interior Door card/panel
Old Dec 28, 2025 | 01:12 PM
s3yang's Avatar
Default Help installing interior Door card/panel
I'm doing the speakers upgrade and reinstalling the door cards but I see this white zip tie thingy that I don't remember fixing it or removing during the removal. Does anyone know what wire harness or "hole" it is suppose to go through and loop back to? It seems to be pushed back into stake on the door but I can't figure out if it's ee thesuppose to secure something from the door card/panel.
See the white plastic wire the red arrow is pointing to.
Old Dec 30, 2025 | 01:20 AM
RoverJoe's Avatar
Community Influencer
It's just there to pull the window regulator up against the panel. So you pull it through until it pops into the panel, and then there should be a little stud somewhere the arrow end can hook onto so it's not loose.
Old Jan 4, 2026 | 07:54 PM
s3yang's Avatar
THanks that makes sense, if I'm not removing the black panel you see in the picture and only the trim panel with the door armrest then I don't need to do anything other than make sure the arrow end is hooked to the stud?
Old Jan 4, 2026 | 09:25 PM
RoverJoe's Avatar
Correct, it's only removed when you are removing the black plastic door card/carrier.
Noah
Jul 29, 2021 06:16 AM
Texasbill
Dec 1, 2018 07:30 AM
mikelish24
Jan 29, 2014 03:48 PM
wardo5757
Feb 12, 2013 08:06 PM
dhoxworth
Feb 15, 2011 06:56 PM
