Help with launch control
Old Jan 20, 2021 | 11:45 AM
dibbyandco's Avatar
Default Help with launch control
Just watched a you tube with someone in an F Type V6s using launch control. They said you have to be in Dynamic mode (yep) and that you must turn off traction control - handbook doesn't say that. Just says left foot on brake, dynamic mode, raise revs to about 2000 until it says "launch control active"
Which is right? Do you have to take traction control off? I thought launch control just modified how traction control operates and you leave it on?
Old Jan 20, 2021 | 11:50 AM
malbec's Avatar
Leave it on.
https://www.ownerinfo.jaguar.com/doc.../proc/G1885680
Old Jan 20, 2021 | 11:52 AM
scm's Avatar
scm
Lots of conditions have to be met for launch control to activate (steering straight ahead, etc.) but traction off isn't one of them.
Old Jan 20, 2021 | 12:22 PM
RGPV6S's Avatar
Don't need to turn off traction control. I got best results in Dynamic/Sport. You will still get a lot of wheel spin even with launch control.
Old Jan 20, 2021 | 06:09 PM
EdG's Avatar
EdG
Agree with above. Traction control can be on or off on my 2016 V6S. Otherwise, as described.
Old Jan 21, 2021 | 03:16 AM
dibbyandco's Avatar
Thanks all, thought that would be the case. Just need a nice dry day and a straight, quiet bit of road to try it out now!
Old Oct 13, 2025 | 01:11 PM
J444G's Avatar
Guys, how long you have/can stay on both brake and gas pedals to activate LC?
From what RPM it starts?
Does it start from 1st or 2nd gear?
I cannot activate it
Old Oct 13, 2025 | 01:23 PM
DJS's Avatar
DJS
This document describes how to activate it, and what it does. Note that this is a pretty dumb implementation - engine RPM is controlled by your right foot, not the ECU. Primarily, it doesn’t do RPM matching during shifts.
https://www.dropbox.com/scl/fi/et754...=c92rsdq9&dl=0
I’ve tried it a few times, not a big deal. Originally, it was only present on the V6S, don’t know about now.
Old Oct 15, 2025 | 07:00 AM
scm's Avatar
scm
It was also present on the 4-pot I had as a loaner back in 20218.
Old Oct 15, 2025 | 08:29 AM
J444G's Avatar
- Depress the brake pedal and hold with the left foot.
- Move the Transmission Control Switch to either theDrive (D) or Sport (S) position
Do I have to be in Park to activate the sequence?
Old Oct 15, 2025 | 04:53 PM
scm's Avatar
scm
No, just apply a few thousand revs until the dash tells you it's activated.
FullChat
Feb 26, 2018 11:20 AM
powerlord
Feb 8, 2017 12:33 AM
cyber3d
General Tech Help
Jul 3, 2015 09:22 AM
F-TypeRookie
Dec 6, 2014 07:15 AM
1Fastcat
Mar 8, 2014 07:31 PM
