High Engine Temp Warning Diagnosis + Story
I mentioned in a previous post, I brought this up to them. They vaccum it out or something, the tech dismissed it.
Yeah. I'm going to warranty it and go back to OEM. Keep it as backup.
https://play.google.com/store/apps/d...g.prowl.torque
Need an OBD2 reader that you connect via Bluetooth or Wi-Fi. It then reads all the sensors in the car and displays it via the app on the phone.
My 2016 has the parasitic drain, whatever I plug in there gives the same issue. Needs a 10 min negative terminal disconnect to reset.
I have a 2021 face-lift and as long I press "quit" in the app then I don't have battery issues.
I once closed the torquepro app without quiting and I came back to the car with low battery and lots of warning messages until I charged and reset battery.
so always shut down properly I have no problems
Tech called today and advised the water pump was found to be the culprit, was replaced by him in my March preventative maint. so i don't have details on mfg. Anywho, warranty and replaced.
Still need an axle and probably a new rad soon, but that's another story and not related.
slmskrs
Jun 12, 2015 12:33 PM
