High Engine Temp Warning Diagnosis + Story
Old Sep 10, 2025 | 09:55 AM
randyb's Avatar
Given your answers, I might have them check for air in the system. I know when my XK was not bled correctly, it ran hot till I had a shop re-bleed the coolant system.
Old Sep 10, 2025 | 10:36 AM
Carbuff2's Avatar
EuroAMP thermostats are aftermarket, aren't they? Might be suspect...
Old Sep 10, 2025 | 11:22 AM
Evoex's Avatar
I mentioned in a previous post, I brought this up to them. They vaccum it out or something, the tech dismissed it.
Evoex's Avatar
Yeah. I'm going to warranty it and go back to OEM. Keep it as backup.
Old Sep 10, 2025 | 12:31 PM
Robert Gilbert's Avatar
How does the Torque app work? Is there an issue with using the OBD2 port and the car shutting down? Is there a link to the app so I get the correct one? Thanks.
Old Sep 10, 2025 | 02:29 PM
Evoex's Avatar
Only available on android.
https://play.google.com/store/apps/d...g.prowl.torque
Need an OBD2 reader that you connect via Bluetooth or Wi-Fi. It then reads all the sensors in the car and displays it via the app on the phone.
My 2016 has the parasitic drain, whatever I plug in there gives the same issue. Needs a 10 min negative terminal disconnect to reset.
Old Sep 10, 2025 | 03:27 PM
Penfold.'s Avatar
I have a 2021 face-lift and as long I press "quit" in the app then I don't have battery issues.
I once closed the torquepro app without quiting and I came back to the car with low battery and lots of warning messages until I charged and reset battery.
so always shut down properly I have no problems
Old Sep 10, 2025 | 04:18 PM
  #28
Evoex's Avatar
Known issue for my year range, I tried to get JLR to code it off. But since my car is out of warranty they wanted me to submit to a 24/hr battery test first and then a plethora of troubleshooting at $260/hr shop rate. /Pass
Old Sep 12, 2025 | 10:01 AM
Evoex's Avatar
Tech called today and advised the water pump was found to be the culprit, was replaced by him in my March preventative maint. so i don't have details on mfg. Anywho, warranty and replaced.
Still need an axle and probably a new rad soon, but that's another story and not related.
Old Sep 12, 2025 | 11:18 AM
  #30
JagCode3's Avatar
Thanks for the update - glad your engine is OK after the high temps.
bigdhenderson
Nov 24, 2020 03:20 PM
slmskrs
Jun 12, 2015 12:33 PM
Bdg6065
Oct 8, 2012 02:09 PM
RJC
Mar 1, 2012 01:37 PM
pdog2000
Jan 31, 2011 07:24 PM
