how to fix Vibrations coming from Central storage?
Old Sep 19, 2021 | 04:44 AM
NeoJFK's Avatar
Default how to fix Vibrations coming from Central storage?
hi guys, I am having horrible vibration wqhen listening to music coming from that plastic trim in the central storage compartment. When i apply pressure on it it does disapear. Any recommendation / solution?
Old Sep 19, 2021 | 04:57 AM
CJSJAG's Avatar
We do not have one of those. They were either discontinued or ot fitted in the convertibles.
Only thought is to see if you can eliminate the problem by packing the space tightly with something that presses against the door from the inside.
That presumes you do not normally use ths cubby.
We just have a string pouch and I find it almost useless because it is behind me while I am driving.
Old Sep 19, 2021 | 05:08 AM
NeoJFK's Avatar
I got the convertible
Hopefully someone from the forum will have solved the isue
Old Sep 19, 2021 | 06:22 AM
DJS's Avatar
DJS
It’s an option on convertibles - mine came with the Premium Pack.
Maybe stuff a microfiber towel in it? Put some foam tape under the lip?
Welcome to the world of lousy F-type sound systems.
Old Sep 19, 2021 | 07:04 AM
CJSJAG's Avatar
My 2021 vert came with the "interior luxury pack" and the "premium interior protection pack".
But no cubby. As previous not missing it!!
Old Sep 19, 2021 | 08:59 AM
TheMoke's Avatar
You could first try using something like permatex silicone spray if you think the squeaky trim pieces are accessible. Or:
Unless there is a YouTube video showing how to remove the panels behind the seat, you probably will need to download the service manual to see what you have to do to get to the cubbyhole. I had a merc convertible with similar issue. Very annoying. You can buy 1mm thick felt and or foam rubber tape to sandwich between the contacting trim pieces. The other method is to use high viscosity silicone grease. Spray or grease silicone lubricant does not harm plastics.
Old Sep 19, 2021 | 09:05 AM
NeoJFK's Avatar
Heyy
Thanks flr those advices. It is litterally the plastic ring. Not squicky just vibrstin with bases
I need somehow to find a way to apply pressure permsnently with the glovebox closed
ill try a cpuplw.of things and figure it out
Any idea hpw to remove that plasric ring?
Svalbard
Jul 3, 2021 08:03 AM
3timejag
Mar 27, 2020 07:06 PM
multistrada74
Mar 13, 2020 01:50 PM
10 XF Premium
Nov 30, 2015 12:39 AM
RUBY
Mar 5, 2012 05:59 AM
