How i fixed the meridian sound
Old Apr 10, 2016 | 03:53 AM
domino_z's Avatar
Default How i fixed the meridian sound
Hi guys
Been puzzled with the low quality of this 'upgraded' meridian audio in the default setting
So i went to see an audio mate of mine, he put a sound recording device inside and let him tweak the audio settings
My car is a september 2015 build (US 2016 spec), so i assume i have the upgraded panel trim to dampen the sound vibrations because i don't get any rattling even in the default audio setting
In the end this is where we ended up. The biggest change was moving the sound stage 2 steps backwards. This stopped the front speakers distorting as it took bass out of them and pushed it back towards the sub in the rear bulkhead, which with aforementioned upgraded trim, just produces clean rattle free bass now.
Old Apr 10, 2016 | 05:26 AM
Nati's Avatar
My stereo (2017) sounds pretty awesome in all modes but I have also settled on DTS, very similar bass and sub settings, and just more treble to my preference. I didn't play with the fader. Will try that.
Old Apr 10, 2016 | 07:48 AM
jaguny's Avatar
Appreciate the info, working the fade is needed to balance the sound. I still believe that no buzzing, rattling should occur unless there is a bad component or design.
Old Apr 10, 2016 | 08:56 AM
Buckingham's Avatar
Agreed. The default settings send too much to the front coaxials. Major adjustments are needed to get the true sound capabilities of this system. I prefer the Meridian setting however.
Old Apr 10, 2016 | 09:03 AM
Unhingd's Avatar
Originally Posted by domino_z
Hi guys
My car is a september 2015 build, so i assume i have the upgraded panel trim to dampen the sound vibrations because i don't get any rattling even in the default audio setting
Very interesting. Through a long series of trial and error settings over the past 9 months, this is extremely close to the settings I finally settled on.
Old Apr 10, 2016 | 08:32 PM
domino_z's Avatar
the front speakers can't do bass, not the speakers themselves, nor the mounts inside the door
the relationship between the bass slider and sub slider is a weird one, and from what i can gather, the bass slider adds bass to all speakers and volume to sub at same time. then when you adjust sub slider it gives even more volume. this is the main problem imo and hasn't been setup correctly from factory
you could remove the door trim, fit some beefier mdf mounts for the speakers, focal bam the door skin and trim, but i don't think it's necessary at this stage - though i will if i end up keeping this car long term (waiting for local launch of r8 plus). i'd focal bam the rear bulkhead too
Old Apr 11, 2016 | 05:30 AM
jaguny's Avatar
I couldn't get my to settle down with any bass or sub over the half way mark. We'll see what the service comes come up with as I would have hoped the factory fix was a complete one. Thanks again for the info.
Old Apr 11, 2016 | 12:07 PM
mikelanzetta's Avatar
Hi guys
This makes sense, but is interesting as I pushed the fade 2 clicks to the front, sounded better to me. I bump up the sub stronger than you have here. I can get plenty of bass, I prefer a stronger treble for separation. Hey as long as you are enjoying it!
Old Apr 11, 2016 | 02:05 PM
pipper678's Avatar
Lightbulb Surround Sound
Sorry to hijack the thread a bit...
But my F-Type S Coupé also is September 2015 built (MY2016) but I haven't got the Surround sound options, nor the separate Bass and Sub sliders in my multimedia unit! Although I do have the newer style - not so blocky, more colorful - media system loaded on it
Does this maybe have to do something with having the 380 instead of the 770 Watt Meridian system?
TIA, cheers
Lyndon
Old Apr 11, 2016 | 02:10 PM
DJS's Avatar
DJS
Yes, the 380W (which I also have - the 2014 version) doesn't have the various surround-sound options. Mine sounds mediocre - no highs to speak of.
oldish git
27
Jul 24, 2020 02:05 PM
Bhpbug
May 3, 2016 12:26 PM
Queen and Country
Apr 18, 2016 11:13 AM
richard1159
Apr 16, 2016 07:54 AM
clivedavies
Apr 7, 2016 10:21 PM
