How to lock doors with bonnet open
Old Jan 23, 2026 | 03:57 PM
crowsash's Avatar
I guess heat soak is not such a problem in more temperate zones but a switch or setting would be helpful, our forecast here for Monday is 41C.
I also do have a homemade Faraday cage, I cut the thumb off a cheap ($5) Aldi butchers glove. The fob squeezes in and works even beside the door handle.
Old Jan 25, 2026 | 08:57 PM
AHarmlessDolphin's Avatar
Originally Posted by crowsash
Hello F type helpers.
My search of various threads seems to indicate the doors/hatch won't lock if the bonnet is up.
Does anyone have a work around for this, I like to leave the bonnet up to reduce the heat soak in the engine bay after a run.
It takes hours so I can't sit around waiting.
any ideas gratefully received.
If you feel this neccasary, these cars did come with a built in turbo timer . After you park and lock restart the car via the InControl app and it will run for up to 30 minutes. If you think your that hot, set the climate control to 90F/32c. You could also consider investing in a ODB app to better determine if you want to leave the bonnet open.
Old Jan 26, 2026 | 01:37 AM
crowsash's Avatar
I think I'll go with the bonnet latch tweak. Seems like a more direct solution but always handy to have options.
Thanks for the suggestion.
essence head
May 11, 2026 11:34 AM
Spurge
Apr 28, 2024 05:02 PM
93xjs6cyl
Sep 29, 2022 11:24 AM
Anil4565
Jan 13, 2018 08:11 PM
bigwiki
Oct 5, 2010 08:26 AM
