How to remove the headlight unit of a F-Type?
Old Dec 17, 2017 | 08:47 PM
plasticol's Avatar
Default How to remove the headlight unit of a F-Type?
Step by step description in how to remove the entire headlight unit of a Jaguar F-Type 2017?
Old Dec 18, 2017 | 11:39 PM
paperboy's Avatar
I found out it can actually be done without taking off the bumper completely when I tried doing it myself.
1. Remove 1 bolt on top center row of bumper bolts(there are multiple, but remove the one closest to the headlight you want to remove)
2. Remove screws on outer edge of bumper, accessible by the fender liner
3. Pull bumper out a few inches to expose the side headlight bolt
4. Remove bolt on side of headlight
5. Remove bolt on top of headlight
Headlight will now be loose and can be pulled out. Be careful as the headlight edges are somewhat sharp and can scratch the paint as you pull it out.
6.Disconnect connector on back
Old Dec 19, 2017 | 01:08 AM
OzXFR's Avatar
Thanks for that, will make changing the headlight globe(s) a lot easier if I ever need to do it again.
Old Aug 10, 2018 | 11:47 AM
Ron Gillespie's Avatar
Should make this a sticky. Great step by step instructions on changing out the headlight and bulb. (Although you can do the passenger side without removing, you do have to move the fuse box though).
0to60in4
May 14, 2025 02:39 PM
domino_z
F-Pace (X761) / C-X17
Oct 27, 2016 05:01 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
