I did not make it tonight
Old Dec 17, 2020 | 10:15 AM
Mahjik's Avatar
Originally Posted by Ray Ray
The tires should be at MOST half worn, I got them last winter and did at most 5k miles total, granted there is the occasional peel out and a little bit of burn out, who can resist!!?
My experience, they were decent but not great the first winter. Then absolutely horrible the second winter. I didn't give them a 3rd winter.
Old Dec 17, 2020 | 10:50 AM
Ray Ray's Avatar
Originally Posted by DJS
I think living in NYC, you should expect a handful of days where the car probably should stay home. A good compromise, I think, to the fun it provides the rest of the year.
Definitely, I was very excited though, last year there were only one real snow and I had so much fun in the parking lot, not this time!!
Noted, I'll probably not buy them again if they are only good for one winter...$1800 is a steep price to pay for that, might as well spring for a set of 255s square set up, maybe even narrower?
Old Dec 17, 2020 | 12:18 PM
DJS's Avatar
DJS
Yeah, this storm (12" here) is the most we've had since I got my AWD XE in the spring of 2018. Haven't been able to play with it, much.
Old Dec 17, 2020 | 05:54 PM
Ray Ray's Avatar
So i actually went out and freed the car today. Production date reads June 2018, front has 6/32 inch, rear has 5.7/32 inch, versus 10/32 new.
(I only measured the outer most straight groove)
God do these wear quick, if they last 2 winters it’s the equivalent of one year tread life???
it’s much drivable now the roads are plowed and slushy. Gonna drive home soon, that’d be the real test.
Old Dec 17, 2020 | 06:49 PM
Ray Ray's Avatar
Safely made it home, city streets were slushy but MUCH MUCH better than last night, completely manageable. highway were clear. next time I will just wait until the snow stops and the roads plowed.
Old Dec 18, 2020 | 07:12 PM
Mbourne's Avatar
wise decision
Old Dec 19, 2020 | 08:15 AM
Unhingd's Avatar
Yes I was in snow mode, rpm hovered around 1k, i had to use more brake than throttle. I also used normal mode with DSC off to back into parking spot, as the ~6" snow pile besides the curb wasn't moving anywhere.
I do have to check it physically to be sure, and the dash TPMS might not be accurate, i will measure those and report back, doesn't seem like im heading out today though, the white stuff is still coming down.
Im thinking everything is fine and my expectation was too high, I will report back when I have the chance to drive it afterward with plowed, possibly icy roads, as the temp will be quite cold for the following days.
The real issue is the tire width. A dedicated winter set of 4 - 19" x 8.5" OEM (front) wheels with 235 or 245 snow tires would be a good choice. A suitable spacer/adaptor will be needed in the rear so that the stance doesn't look wierd. Also, at 36 psi, you are still too high for maximum traction. Drop that down to 32 unless you are typically travelling 100+mph this time of year. Also, toss 2 or 3 big bags of sand in the boot.
Old Dec 19, 2020 | 10:36 AM
  #28
Mahjik's Avatar
FWIW, did all that in the past as those are standard winter suggestions. However, when the tires suck, no amount of mitigations will help.
Old Dec 19, 2020 | 10:40 AM
Unhingd's Avatar
All too true. Those Sotto Zeros are Pirellis, after all.
JagWire_5280
XF (X260)
Sep 5, 2021 08:40 AM
Civicalized
XJ40 ( XJ81 )
Oct 31, 2018 01:51 PM
cue244
44
Nov 2, 2014 01:26 PM
XJRChad
Nov 23, 2013 08:27 AM
dannygjatt
Dec 11, 2011 10:27 AM
