Illuminated tread plates.
Old Mar 26, 2018 | 12:24 PM
Paul Calvert's Avatar
Default Illuminated tread plates.
For cars that dont have the illuminated tread plates (like mine) there is the option via the T2R6090 accessory to upgrade them. It is a bit of a daunting job though as quite a bit of disassembly is needed. Anybody thinking of doing it themselves might find the attached helpful.
Old Mar 26, 2018 | 12:32 PM
sts-v's Avatar
Banned
$600 for that?
Old Mar 26, 2018 | 12:49 PM
$150 off ebay :-)
Old Mar 26, 2018 | 12:51 PM
Suaro's Avatar
I think illuminated tread plates can be cool on some cars, but I don't think the F-Type is one of them for two reasons. One, the F is a relatively small vehicle and can only carry so much signage before you start to feel crowded, and Two, JLR has put "Jaguar" on a lot of surfaces already, door handles (2), wheel caps (4), engine vents (2), air vents (4), lights (2), trunk, grill, info panel, mats (2), and of course, the tread plates (2). Enough already.
(Personal opinion, of course. There is no right answer. Only what you like and what makes you happy.)
Old Mar 26, 2018 | 12:57 PM
Personal opinion, and everyone can have their own point of view, but I think its a nice touch. And just for info the plain sill treads have jaguar stamped on them, so your not really increasing the number of occurrences of jaguar:-)
Old Mar 26, 2018 | 09:50 PM
Magical's Avatar
It is a nice touch. Good work Paul.
What I am looking for is the illuminated insignia to put under the door, when the door opens it lights up the ground . Mercedes has it. I don't know where to look for it.
If anyone knows of it, let me know.
Old Mar 26, 2018 | 10:02 PM
OzXFR's Avatar
Plenty on Fleabay, just search using "Jaguar F-Type projector lights".
I put a set of these in shortly after I got the car, they look great, child's play to fit, and never had a single problem with them: https://www.ebay.com.au/itm/2x-JAGUA...oAAOSwSRVanPpQ
Old Mar 26, 2018 | 10:14 PM
zmoothg's Avatar
I added them to my car and they are worth it to me.
Old Mar 27, 2018 | 05:21 AM
jaguny's Avatar
I have the illuminated sills and get the "ohs and has" from passengers that see them (primarily at night, which is all the time in winter here). I like them as well. There are some additional threads you can reference. See "Related topics" at bottom of this page.
Old Mar 27, 2018 | 10:03 AM
Magical's Avatar
Thanks Oz. You nailed it. I have to search because the link you sent does not ship to US.
Old Mar 27, 2018 | 12:37 PM
Magical's Avatar
Interestingly enough, I realized that no door lights were coming on. Thankfully, it was a reset. Hold the top center light button in for 5 seconds, and they work. I am looking into the puddle lights that reflect on the ground, just have to find the plug and play like OZ suggested.
Old Apr 8, 2018 | 10:56 AM
Magical's Avatar
Default puddle lights/shadow lights
By far the easiest install ever and they look good.
Old Apr 8, 2018 | 05:38 PM
Andy2017's Avatar
Exactly.
And, I love the illuminated tread plates on my Jag. Guests always comment on them favorably too.
Old Apr 9, 2018 | 06:42 AM
sts-v's Avatar
Banned
Anyone have the link to the $150 ones?
Old Apr 9, 2018 | 07:11 AM
Unhingd's Avatar
https://www.ebay.com/sch/i.html?_fro...2R5985&_sop=15
Old Apr 9, 2018 | 07:55 AM
Nati's Avatar
It may already be understood, but there is no going back once you try to remove the tread plates. They are destroyed in the process.
Old Apr 9, 2018 | 08:12 AM
mshedden's Avatar
I think member FR500GT managed to get them off intact by using a heat gun / blowtorch(!) to soften the glue holding them on (double sided tape), and then gently prying them up.
Old Apr 9, 2018 | 08:14 AM
I can concur, the level of force required to remove them distorts the plate. Unless you are a very good metal worker getting them straight again wont be easy.
Old Apr 9, 2018 | 10:26 AM
stmcknig's Avatar
If it helps to see where the glue tape runs here is a photo from when I replaced mine with the British Design version which I much prefer over the stock, the smoother finish to the aluminium I really like.
Can confirm I did pretty much destroy the previous ones and almost destroyed some fingers even with heat gun and pry tools.
Old Apr 9, 2018 | 11:08 AM
using mine for the door step in the garage :-)
