InControl generating false security alerts
Old Jul 2, 2025 | 02:23 AM
masaccio's Avatar
Default InControl generating false security alerts
My InControl in my F-Type convertible is currently generating a lot of false alerts. Sometimes as many as half a dozen a day. I can’t really disable it as the car is more difficult/expensive to insure without a tracker in the UK. Obviously I could install a third-party tracker but I did pay for this service so want it to work.
The call centre say it’s an ‘antenna fault’ but my Jag independent has no idea what the cause of that is. I can see a main dealer wanting to replace the telematics unit or all sorts of nonsense that drives up the cost.
Has anyone found a cure that doesn’t involve parts that apparently cost over a grand from a main dealer?
Old Jul 2, 2025 | 11:46 AM
BigJay13's Avatar
Have you tried simply removing the Telematics battery and leaving it out for 10 minutes? Then reconnect it and reset the telematics? It might work as this is what I had to do before I could get the right battery in for mine. Either way I hope you find a solution
Old Jul 2, 2025 | 12:07 PM
masaccio's Avatar
That’s what I plan to try. The TCU is less accessible in the convertible it seems as you need to take the roll bars off to get the fascia out. But replacing the battery seems plausible.
Old Jul 3, 2025 | 02:48 AM
masaccio's Avatar
Just logging some new information for anyone else with this. There are two battery types:
Battery Telematics T4N2591
2014 model with VIN ending K47319
Battery Telematics T2R23864
Later years with VIN ending K47320
Also, the company that runs the security alert response for InControl is able to disable the specific alert that is triggered for me (an antenna alert). Right now I’m not getting the alerts so that appears to have worked. In theory the remaining tracker alerts will continue to work.
Old Jul 3, 2025 | 02:51 AM
masaccio's Avatar
Oops, that should be the last VIN for the ‘91 battery and first applicable VIN for the ‘64 battery.
Old Jul 3, 2025 | 01:26 PM
Lothar52's Avatar
Since day one of my XE and both Ftypes I have decided to test out Jaguar new "Out of Control" program...I wouldn't use this stuff if they paid me....more crap to break. Wonder if there is a way to remove it completely. I don't want any more technology then my 12 and 13 XK's I have apart from blind side warning in mirror...that is nice! Bluetooth streaming added to the XK with a 30 dollar bovee fix and works seamlessly..newer jags don't need that thankfully
Konkapot
May 13, 2024 09:07 PM
TX69XKE
Sep 13, 2021 05:04 PM
Spyderturbo007
Jul 12, 2021 07:50 PM
rwanou
Sep 9, 2020 04:00 AM
ssaeed1973
Sep 21, 2018 12:17 AM
